Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Starting debug server
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Mark Griffiths
over 13 years ago
Note: This was originally posted on 22nd May 2013 at
http://forums.arm.com
I was using DS5 fine for connecting to my Altera board and then today it just stopped working, even the examples do not work. So when trying to load the baremetal example, I get this error:
Waiting for debug server to start accepting connections
processrunner.py:8: RuntimeWarning: Unable to determine _shell_command for underlying os: nt
import subprocess
RDDI-DAP-DS : ERROR failed to connect to RDDI DAP target
RDDI Error Code 4107 : Connection to target failed.
RDDI DLL = rddi-dap_altera_2.dll
RDDI CFG = C:\Users\mgriffit\AppData\Local\Temp\ds5_8070900945896429705.txt
Failed to launch debug server. Command:
/debug_server\vstrm_serverd_rddi.exe -rddi_dap_dll rddi-dap_altera_2.dll -rddi_dap_cfg \Local\Temp\ds5_8070900945896429705.txt -pollrate 200
exited with error code: 1
Any ideas what to try? What could have happened?
Michael Darling
over 13 years ago
Note: This was originally posted on 23rd May 2013 at
Could you tell me what version and build of DS-5 you're running and and on what OS? It looks like something is going wrong in the code that builds up the command to launch the debug server.
Regards,
Mike
Cancel
Vote up
0
Vote down
Cancel
Mark Griffiths
over 13 years ago
I am using Windows 7 and Redhat, on both OSs it did not work. However I randomly changed the dip switches and then it started working again. Orginally, I had them as stated in the Altera Cyclone manual. Now I am not 100% sure why it works or which configuration I have
Any extra knowledge would be welcome.
Thanks,
Cancel
Vote up
0
Vote down
Cancel
Michael Darling
over 13 years ago
Hi, well I was thinking something was wrong with the runner scripts that may be OS or OS+environment dependent. However, your response leads me to conjecture that the switch settings on the board may have changed the configuration so that debug wasn't possible by the route you are choosing. The switches and DIPs on the Cyclone board I have can be used to enable JTAG or USBBlaster debug of the ARM cores in the system. The error message doesn't help us identify that though.
Regards,
Mike.
Cancel
Vote up
0
Vote down
Cancel
Voroshazi Zsolt
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
