Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Vector shift with Neon error
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
John Mudumbe
over 13 years ago
Note: This was originally posted on 28th March 2013 at
http://forums.arm.com
Hi Everyone,
I am trying to shift elements in the vectors with a constant int variable,
but i get an error during compile time saying :
arm_neon.h:3850 error: argument must be a constan
t.
whenever i replace the constant int variable with a constant value , the compiler works just fine.
I have tried to search for solutions online but i am not getting anywhere.
I am using a 2009q arm tool chain and I also tried the using the Dstream tool chain but it is not working for arm cortex A8.
if anyone heres my cry for help and has a solution please reach out and help urgently..
Peter Harris
over 13 years ago
Can you please give a code sample - it's hard to work out exactly what you have done without seeing the code.
I suspect you are trying to give it a "const int", which is not a compile time constant and therefore invalid. The shift amount is not passed in a register, it is part of the instruction encoding.
HTH,
Iso
Cancel
Vote up
0
Vote down
Cancel
John Mudumbe
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Simon Pilgrim
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
John Mudumbe
over 13 years ago
Note: This was originally posted on 4th April 2013 at
I wanted to know, am running the MVC code on arm-cortex A8 and I want to see how much of the code is optimized, is gprof- good enough or is there any other tool I can use?
I have noticed that the gprof is not consistent in terms of time calculations spend on all procedures.
What other tool can I use to find time precision?
Converting the above code in assmbly language will it also improve the neon optimization or there is no difference at all?
Cancel
Vote up
0
Vote down
Cancel
