Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Can DS5 compile Linux kernel module?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
120 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Ali Ayoub
over 13 years ago
Note: This was originally posted on 4th December 2012 at
http://forums.arm.com
I have a newbie question re using ARM DS5.
Is DS5 compiler capable of compiling Linux kernel module? or it's limited to user space applications only?
Thanks,
AAli
Scott Douglass
over 13 years ago
Note: This was originally posted on 7th December 2012 at
DS-5 comes with a Linaro gcc which can be used to build kernel modules and even the kernel on a Linux host.
Since armcc and gcc can be set to use the same ABI it's feasible to build some files with armcc and link the object files together with gcc-built object files.
But armcc does not do GNU inline asm nor GNU asm syntax and cannot be used to build the kernel (and I suspect it won't entirely build most kernel modules).
Cancel
Vote up
0
Vote down
Cancel
Abel Zhang
over 13 years ago
Note: This was originally posted on 18th December 2012 at
Culd ARMCC in DS-5 pro be used to compile the native code of Android NDK? If could, then how to do?
We try to use ARMCC to compile NEON intrincis in the native code of Android NDK, but found none guideline or articles. any sugessions? thanks a lot...
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
[It would be better to start a thread since your question is about a different topic. But I'll answer it here anyway.]
Unfortunately, building general native Android code with armcc is not supported* so there aren't any instructions in the documentation, but if you have a standalone object file built with armcc you can link it with other native code. gcc can also compile NEON intrincics.
One reason is that the Android C library, Bionic, does not supply all of the functions that the AEABI requires.
Cancel
Vote up
0
Vote down
Cancel
Abel Zhang
over 13 years ago
Note: This was originally posted on 19th December 2012 at
Thanks for your kindly reply!
quote name='scott' timestamp='1355829081' post='40270']
[/quote]
Cancel
Vote up
0
Vote down
Cancel
