Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
DS5v5.10 Linux Kernel & Application Workshop with Snowball
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Fadil Saat
over 13 years ago
Note: This was originally posted on 6th July 2012 at
http://forums.arm.com
Hi all,
Pardon my noob status - I'm trying to follow the above tutorial but stuck at downloading the Linux Kernel to my Snowball (page 89). The instruction reads "In order to find the kernel sources, duplicate the deb line in /etc/apt/sources.list.d/hwpack.linaro-landing-team-ste.list and replace deb with deb-src". How do I carry out this instruction? I'm really confused!
FadilSG
Scott Douglass
over 13 years ago
You need to edit the file on the target. There are various ways to do that. You could be use vi or some other editor over the serial console. You could use Remote System Explorer in Eclipse to open and edit the file. Since it's small, you could compose the file on the host and then use cat [sic] and paste over the serial console.
Cancel
Vote up
0
Vote down
Cancel
Fadil Saat
over 13 years ago
So I just need to open the file in RSE view on DS5 and replace deb with deb-src? OK thanks for the info!
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
Mostly ... the instructions say to duplicate the line and make the change in the copy. The file will have both the original line and the changed copy.
Cancel
Vote up
0
Vote down
Cancel
Fadil Saat
over 13 years ago
Note: This was originally posted on 9th July 2012 at
Ok, got that. Now I'm stuck at another part of the workshop. I'm doing Debugging Kernel Initialisation after MMU is turned on (skipped 'debugging before MMU is turned on' as it seemed optional). When I completed debug configurations, it landed at this stage (see attachment). How to fix this?
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
The screenshot looks pretty much as I would expect for connecting to a running, idle kernel. Except that you've managed to link the Commands view to "U-Boot". You probably want to change it to "Linked: kernel".
If there's a different problem, can you give more details of what you expect and what is different?
Cancel
Vote up
0
Vote down
Cancel
Fadil Saat
over 13 years ago
Note: This was originally posted on 10th July 2012 at
OK I've changed the command line to kernel. I've actually went back to debugging before the MMU gets turned on. A few bumps along the way but I managed to sort them out.
Currently I'm at page 24. My snowball still hasn't fully booted up Linux, so when the instructions state, "When the kernel finished booting it will prompt you to login. Type ls to the terminal window to list the files in the current directory", what does it mean? I have to let Linux be fully loaded? I tried that and I can't proceed to the next instruction.
FadilSG
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
Yes, if the debugger has the target stopped, the kernel won't be able to finish booting. I think that page is missing: "Clickthe Continue button and let the kernel finish booting." above "When the kernel finished booting..."
Cancel
Vote up
0
Vote down
Cancel
