Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
DS-5 CE issue with Android and Pandaboard (OMAP4430)
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Andre Jestel
over 13 years ago
Note: This was originally posted on 9th March 2012 at
http://forums.arm.com
I got TI's Pandaboard (OMAP4430) and use it with Google's Android 4.0.3. Executing apps which got native code-parts works fine with Eclipse over ADB. Then I tried DS-5 CE and did everything according to the 'How to Install/Debug' pages.
The moment I click on 'Debug' at the DS-5 debug dialog it starts connecting and then I got an error-message:
"jRDDI does not support windows.x86_64
Unable to connect to C:\Users\....AppData\Local\Temp\gdbserver8901675109249321715.xml"
Does anybody know what I could do ?
By the way,
what I want to do in the end is access the memory-mapped GPIO-pins on the board. To prevent segmentation faults when I wirte logical ones and zeros the physical addresses I would disable the MMU to get flat-mapping.
This is possible only in privileged CPU-modes. So if my app executes a SVC-instruction the mode will change but the CPU now jumps to the SVC-handler. Is it possible by using the DS-5 (CE) to change the content of CPU registers and/or memory-addresses ? If not what tools would I need ? Like DS-5 basic/full and is USB-Debugging enough or must I use a JTAG-Debugger ?
Thanks a lot!
Andrew
Andre Jestel
over 13 years ago
Note: This was originally posted on 13th March 2012 at
THANK YOU !
Cancel
Vote up
0
Vote down
Cancel
Andre Jestel
over 13 years ago
Note: This was originally posted on 15th March 2012 at
OK, now I tried the 32bit Eclipse version and now I get:
An internal error occurred during: "Connecting to Target".
C:\Users\...\AppData\Local\Temp\@1331832276727#2081069398-temp\com\arm\rddi\windows.x86\msvcp71.dll: Can't find dependent libraries
Cancel
Vote up
0
Vote down
Cancel
