Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
DS-5 Problem starting gdbserver to debug android NDK application
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Nivelinn Pantev
over 13 years ago
Note: This was originally posted on 29th December 2011 at
http://forums.arm.com
Hi Everyone,
I am facing problem when starting debug session for native code debugging using DS-5 CE,
This is what is shown:
eclipse.buildId=M20110909-1335
java.version=1.6.0_26
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.cpp.product
Error
Wed Dec 28 20:51:17 EET 2011
Failed gdbserver configuration:
Timeout. PID not found!
com.arm.debugger.control.target.TargetControllerException: Failed gdbserver configuration:
at com.arm.debugger.control.target.TargetController.runGDB(TargetController.java:623)
at com.arm.debugger.control.target.TargetController.setupAndroid(TargetController.java:108)
at com.arm.debugger.control.target.TargetController.setupGdbServerOnTarget(TargetController.java:121)
at com.arm.debugger.control.target.TargetController.setupTarget(TargetController.java:78)
at com.arm.debugger.control.ConnectionController.doPreDebugServiceInitialization(ConnectionController.java:592)
at com.arm.debugger.control.ConnectionController.doInitialize(ConnectionController.java:533)
at com.arm.debugger.control.ConnectionController.manageThreadModelAndInitialize(ConnectionController.java:524)
at com.arm.debugger.control.ConnectionController.manageConnectionCleanupAndInitialize(ConnectionController.java:510)
at com.arm.debugger.control.ConnectionController.manageProgressResourceAndInitialize(ConnectionController.java:463)
at com.arm.debugger.control.ConnectionController.initializeNonModelConnection(ConnectionController.java:435)
at com.arm.debugger.control.ConnectionController.initialize(ConnectionController.java:410)
at com.arm.debugger.control.ConnectionManager.createConnection(ConnectionManager.java:391)
at com.arm.debugger.launcher.TargetLauncher.connect(TargetLauncher.java:70)
at com.arm.debugger.launcher.TargetLauncher.launch(TargetLauncher.java:44)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:928)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1132)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
The set-up the environment is based on these guidelines:
http://infocenter.ar...h/CIHEEGJH.html
http://kernel.ozandroid.info/?p=83
I am on 32 bit Ubuntu 11.10 host and debugging is on avd API level 14
What could be the problem?
Thanks a lot in advance!
Albert Cano Camps
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Nivelinn Pantev
over 13 years ago
Note: This was originally posted on 4th January 2012 at
Hi Albert,
And thanks a lot for your assistance!!!
I am going to perform the suggested tests ASAP and let you know what the results are!
Thanks again,
Best Regards,
N
Cancel
Vote up
0
Vote down
Cancel
Nivelinn Pantev
over 13 years ago
Note: This was originally posted on 7th January 2012 at
Hi Guys,
I tried once more with hello neon example from NDK.
No problem to install and run the application via adb
app_40 2673 1103 119440 30764 ffffffff 400b03c4 S com.example.neon
No problem as well to install and debug Java part via ADT plug-in.
But this is what logcat is showing when trying DS-5:
01-05 17:29:39.184: D/AndroidRuntime(6871): Shutting down VM
01-05 17:29:39.196: D/dalvikvm(6871): GC_CONCURRENT freed 101K, 77% free 483K/2048K, paused 1ms+1ms
01-05 17:29:39.196: D/jdwp(6871): Got wake-up signal, bailing out of select
01-05 17:29:39.196: D/dalvikvm(6871): Debugger has detached; object registry had 1 entries
01-05 17:29:39.226: I/jdwp(89): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.226: I/AndroidRuntime(6871): NOTE: attach of thread 'Binder Thread #3' failed
01-05 17:29:39.237: I/jdwp(143): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.268: I/jdwp(157): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.277: I/jdwp(167): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.309: I/jdwp(184): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.326: I/jdwp(213): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.336: I/jdwp(229): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.364: I/jdwp(258): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.382: I/jdwp(291): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.417: I/jdwp(309): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.432: I/jdwp(326): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.459: I/jdwp(350): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.489: I/jdwp(369): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.489: I/WindowManager(89): createSurface Window{415cae40 Starting com.example.neon paused=false}: DRAW NOW PENDING
01-05 17:29:39.497: I/jdwp(394): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.516: I/jdwp(412): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.538: I/jdwp(800): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.558: I/jdwp(829): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.596: I/jdwp(872): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.618: I/jdwp(941): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.076: D/dalvikvm(6882): Not late-enabling CheckJNI (already on)
01-05 17:29:40.149: I/ActivityManager(89): Start proc com.example.neon for activity com.example.neon/.HelloNeon: pid=6882 uid=10040 gids={1015}
01-05 17:29:40.198: I/jdwp(89): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.207: I/jdwp(143): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.234: I/jdwp(157): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.246: I/jdwp(167): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.258: I/jdwp(184): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.286: I/jdwp(213): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.308: I/jdwp(229): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.329: I/jdwp(258): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.339: I/jdwp(291): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.357: I/jdwp(309): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.377: I/jdwp(326): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.422: I/jdwp(350): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.438: I/jdwp(369): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.458: I/jdwp(394): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.468: I/jdwp(412): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.478: I/jdwp(800): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.496: I/jdwp(829): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.518: I/jdwp(872): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.539: I/jdwp(941): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.828: W/NetworkManagementSocketTagger(89): setKernelCountSet(10040, 1) failed with errno -2
01-05 17:29:41.078: D/dalvikvm(6882): Trying to load lib /data/data/com.example.neon/lib/libhelloneon.so 0x413469f0
01-05 17:29:41.088: D/dalvikvm(6882): Added shared lib /data/data/com.example.neon/lib/libhelloneon.so 0x413469f0
01-05 17:29:41.088: D/dalvikvm(6882): No JNI_OnLoad found in /data/data/com.example.neon/lib/libhelloneon.so 0x413469f0, skipping init
01-05 17:29:41.198: I/helloneon(6882): enter app.....
01-05 17:29:44.216: V/PhoneStatusBar(143): setLightsOn(true)
It seems problem to run gdbserver.
I tried on a real Android device (Linaro Android on i.MX53 QSB), again application is installed and started, but gdbserver PID cannot be found:
logcat:
01-08 00:38:23.110: D/AndroidRuntime(1931): Calling main entry com.android.commands.am.Am
01-08 00:38:23.150: I/ActivityManager(1176): START {flg=0x10000000 cmp=com.example.neon/.HelloNeon} from pid 1931
01-08 00:38:23.210: D/dalvikvm(1941): Not late-enabling CheckJNI (already on)
01-08 00:38:23.220: D/AndroidRuntime(1931): Shutting down VM
01-08 00:38:23.220: I/ActivityManager(1176): Start proc com.example.neon for activity com.example.neon/.HelloNeon: pid=1941 uid=10040 gids={1015}
01-08 00:38:23.240: D/dalvikvm(1931): GC_CONCURRENT freed 101K, 77% free 483K/2048K, paused 0ms+1ms
01-08 00:38:23.240: I/AndroidRuntime(1931): NOTE: attach of thread 'Binder Thread #3' failed
01-08 00:38:23.240: D/jdwp(1931): Got wake-up signal, bailing out of select
01-08 00:38:23.240: D/dalvikvm(1931): Debugger has detached; object registry had 1 entries
01-08 00:38:23.430: D/dalvikvm(1176): GC_EXPLICIT freed 340K, 19% free 10201K/12487K, paused 4ms+8ms
01-08 00:38:23.580: D/dalvikvm(1941): Trying to load lib /data/data/com.example.neon/lib/libhelloneon.so 0x41052a48
01-08 00:38:23.580: D/dalvikvm(1941): Added shared lib /data/data/com.example.neon/lib/libhelloneon.so 0x41052a48
01-08 00:38:23.590: D/dalvikvm(1941): No JNI_OnLoad found in /data/data/com.example.neon/lib/libhelloneon.so 0x41052a48, skipping init
01-08 00:38:23.610: I/helloneon(1941): enter app.....
01-08 00:38:24.030: W/ActivityManager(1176): Activity pause timeout for ActivityRecord{411f2e40 com.example.neon/.HelloNeon}
01-08 00:38:25.990: I/WindowManager(1176): createSurface Window{411f15e0 com.example.neon/com.example.neon.HelloNeon paused=false}: DRAW NOW PENDING
Cancel
Vote up
0
Vote down
Cancel
Albert Cano Camps
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Nivelinn Pantev
over 13 years ago
Note: This was originally posted on 9th January 2012 at
Well, negative as well.
the application is running:
app_40 691 37 130940 34864 ffffffff 40011384 S com.example.neon
but:
Error
Mon Jan 09 19:38:01 EET 2012
at com.arm.debugger.launcher.TargetLauncher$ConnectJob.run(TargetLauncher.java:99)
Cancel
Vote up
0
Vote down
Cancel
Albert Cano Camps
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
