Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
exception for big endian
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Zhanguo Li
over 13 years ago
Note: This was originally posted on 2nd September 2009 at
http://forums.arm.com
Hello experts,
I am trying to modify my software platform and application for big endian(BE8) mode, and the hardware platform is ARM's PBX-A9 board. Firstly, the timer interrupt doesn't work and since it's a little complex to debug timer interrupt, I decide to produce a software exception to see whether the exception process works or not. However, after the "SWI" instruction is performed, the CPU doesn't "jump" to exception vector(for SWI exception, the address is 0x08), and of course, the system hang.
If I switch the system to LE mode(using "SETEND LE") in my BE system before the "SWI" instruction(I also adjust the exception process routine at address 0x08 for LE mode), and CPU can jump to address 0x08 for this software exception. For BE mode, I have configured the exception process routines at 0x08 carefully and I can ensure that it can work(at least, can output a char through serial port), but it looks that the SWI doesn't lead PC to 0x08 for BE mode.
I boot my system from ARM's boot monitor, and then switch to BE mode through "SETEND BE" instruction.
Has anyone run with BE mode sucessfully for Cortex-A9? Could you tell me how to support exception and interrupt for BE mode?
Thanks much for your help!
-Jerry
Peter Harris
over 13 years ago
From a processor point of view, you need to set bit 25 (EE) of the System Control Register in CP15 to ensure that exceptions are taken with the processor in "Big Endian" mode.
Cancel
Vote up
0
Vote down
Cancel
Zhanguo Li
over 13 years ago
Thanks for your response! I just fixed this issue. I think your hint is in the same way that I fixed it. Thanks again.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
One observation on the timer not working.... The private address space of the A9 (including the private timers) is fixed as little endian format.
Cancel
Vote up
0
Vote down
Cancel
