Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Problem with arm_cfft_f32()
Jump...
Cancel
Locked
Locked
Replies
Subscribers
120 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Pierre Bellier
over 13 years ago
Note: This was originally posted on 27th August 2013 at
http://forums.arm.com
I'm new in the field of ARM and I need some help. I try to make a FFT on a Cortex-M4 with fpu. I tried two examples given with the CMSIS library, an old one which uses
arm_cfft_radix4_f32()
and a new one with
arm_cfft_f32()
. The two examples compile well. The old code with
works quite good. That function is deprecated so I would like to use
arm_cfft_f32()
but I don't get the right data at the end.
The program makes a FFT of a given signal and should detect the peak in magnitude at
refIndex = 213
. It's ok with the deprecated function
but not with
arm_cfft_f32()
. I get
refIndex = 861
. I tried to change the '
doBitReverse
' value from 1 to 0 but nothing changed I have exactly the same result at the output of
arm_cfft_f32()
I didn't find the same issue on the web. Is there a known problem with arm_cfft_f32() ? Could someone explain me what I'm doing wrong ?
Thanks,
Pierre.
Pierre Bellier
over 13 years ago
Note: This was originally posted on 28th August 2013 at
Thank you for the answers.
TerryGuo, I tried the different define macros but it doesn't change anything.
dwwhite, I'm using Atmel Studio with GCC. The library I use was compiled by Atmel and is included in the AtmelStudio installer. I suspect that there is a problem with it. I tried yesterday to recompile the library for GCC but I didn't find how to do. I have some batch scripts to compile for GCC with Keil but it fails.
I feel that the bitreverse operation is not performed (same result when activated or not, the cycle counter is only five counts higher when enabled).
I don't know if it is important but I use the fpu with
-mfloat-abi=hard
flag. I tried also without fpu (
-mfloat-abi=soft
) but I get the same result.
Is the library you compiled compatible with GCC ?
Cancel
Vote up
0
Vote down
Cancel
Pierre Bellier
over 13 years ago
-mfloat-abi=hard
-mfloat-abi=soft
Cancel
Vote up
0
Vote down
Cancel
