Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Cortex Microcontroller Peripherals Interface Standard (CMPIS)
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Kool King
over 13 years ago
Note: This was originally posted on 23rd November 2012 at
http://forums.arm.com
The need for a Cortex Microcontroller [size="3"]Peripherals Interface Standard (CMPIS)[/size]
Personally I got scared after reading this topic about ARM Cortex-M processors and CMSIS:
http://www.avrfreaks...wtopic&t=127016
At first, CMSIS appeared to me as a standard interface between the programmer and Cortex-M controllers including their peripherals.
Little by little I have realized that despite the fact CMSIS makes some order in the world of ARM microcontrollers, produced by many companies, it leaves the peripherals at the mercy of each vendor. There are hundreds of API functions for setting and working with peripherals just for a single manufacturer. For example, if it happens someone starts with ARM controllers produced by TI and learns Stellaris Peripheral Driver Library (
http://www.ti.com/li...9o/spmu019o.pdf
) and after some time he has to move to NXP LPC ARMs he is simply obliged to assimilate a new set of APIs different from the one Stellaris uses.
I understand vendors desire to add various, more or less exotic features, to peripherals to make their ARM based controller distinct from those built by other manufacturers but a set of common basic API functions for :Timers, ADCs, I/O ports, etc., able to make each peripheral functional at minimum, will make the life of programmer much easier when they have to port an application from one Cortex-M to another.
At the moment, even with CMSIS, adapting a source code written for an ARM uC to another is nearly as difficult as porting a program between two unrelated microcontrollers.
xuesong renjun
over 13 years ago
Note: This was originally posted on 28th December 2012 at
Hello, Simplex and Reinhard:
Have you heard about CooCox and CoX?
I found CooCox have write a library that looks like a standard interface and library, it is CoX library.
This library include the PeripheralsInterface Standard.
They have support Peripherals such as GPIO, ADC, UART, etc.
And there are CoX libraries for STM32F10x series and Freescale M0+ series. They also have the plan for NXP and TI.
They said that " drivers based on CoX can be ported to other MCU easily."
I haven't use CoX before, but it seems to be very easy to use if I want to learn how to start with ARM.
What do you think about that?
Cancel
Vote up
0
Vote down
Cancel
xuesong renjun
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
