Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
CMSIS RTOS RTX invalid thread id token ?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Mike Davies
over 13 years ago
Note: This was originally posted on 8th August 2012 at
http://forums.arm.com
I am using Keil's RTX implementation of the CMSIS RTOS and need to communicate between an interrupt routine and a thread. I intend to use the osSignalSet() call for this which the documentation says is suitable for use in an interrupt routine. This function takes an osThreadId parameter which I intend to store in a global variable for access by the ISR and will set it from the thread.
My question relates to interrupts that might conceivably occur before the creation of the thread : I need a default value to use for the osThreadId which can never occur as a real thread id. Obviously Keil's RTX comes complete with source and I am pretty sure "NULL" is a suitable value but the CMSIS RTOS documentation states that the implementation of osThreadId is implementation defined so I cannot rely on this being always true. I have looked up and down "cmsis_os.h"but cannot find any #define like GUARANTEED_INVALID_THREAD_ID, so can anyone tell me whether this is an oversight in CMSIS RTOS, or am I missing something ?
Also, while I am here, my use above of a global variable to communicate data between an ISR and a thread is quite common but very ugly. I am new to ARM Cortex and I wondered if there is anything I am missing in terms of alternatives ? I am reminded of the early days of Windows when Windows drivers communicated with DOS counterparts via software interrupts in an arrangement like a kind of multi-level dumb waiter, I can't remember what they called that arrangement but is there anything in the Cortex that would allow a similar scheme to work ?
Many thanks,
Mike
Bastian Schick
over 13 years ago
Passing thread-IDs via global variables is nothing ugly unless these are "constant".
In your case, since threads are created on start-up the thread-id won't change later on.
Regarding your problem, the simplest thing is to activate the interrupt from within the foreground thread.
So it is sure the global thread-id is valid.
Cancel
Vote up
0
Vote down
Cancel
Bastian Schick
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
