Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
[CMSIS] RTX to CMSIS-RTOS gives hard fault
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Andrew Lucas
over 13 years ago
Note: This was originally posted on 18th September 2012 at
http://forums.arm.com
So I had my project working under the old Keil-rtx rtos and I decided to move to the cmsis-rtos version.
It seemed pretty straight forward. I grabbed the new RTX_CM4.lib file, the updated RTX_Conf_CM.c file and I am now including the cmsis_os.h file instead of rtl.h.
Anyway I got everything to compile file but when I run it, during my uart initialization in the main routine, prior to initializing any tasks, I get a hard fault on my first call to any NVIC function. I am using the STM32F407VG with the ST standard peripheral library.
Anyone have an idea what I might be different with the cmsis-rtos version of the OS.
Thanks,
Andrew Lucas
over 13 years ago
Note: This was originally posted on 19th September 2012 at
Solved my own problem. Turns out the new RTX_Conf_CM.c file was set for unprivileged mode. Once I changed it bingo!
Cancel
Vote up
0
Vote down
Cancel
Reza PRL
over 13 years ago
Note: This was originally posted on 28th April 2013 at
I have problem like you, I'm configured RTC_Conf_CM.c to privileged mode, and I want to run cmsis os on FTP demo that is sample code from keil company, but it doesn't work my TCP !!!
Do you have any information about it
Cancel
Vote up
0
Vote down
Cancel
