Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARM Cortex-M0 on thin board
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Numaan Chaudhry
over 13 years ago
Note: This was originally posted on 23rd February 2012 at
http://forums.arm.com
Hello to all
This is my first post - I'm looking forward to talking to all you guys.
I'm not too familiar with this aspects of embedded devices so this might be a basic question about the M0 - I'd like it to fit on a 3'' x 1'' board but the boards I see online - for example on here
http://www.keil.com/boards/cortexm.asp
- are all 3'' x 3''.
Am I missing something....?
Alban Rampon
over 13 years ago
Note: This was originally posted on 24th February 2012 at
Hi nchaud and welcome,
If you are looking for something smaller on the
ARM Cortex-M0
, may be you will like the new mbed.
http://mbed.org/hand...icrocontrollers
Anything special you want on your board?
Kindly,
Alban
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Beside from mbed.org, there are quite a few.
For example,
http://www.keil.com/arm/mcbnuc1xx/
(possibly not as thin as 1 inch)
http://shop.ngxtechnologies.com/product_info.php?products_id=103
http://www.nuvoton.com/NuvotonMOSS/Community/ProductInfo.aspx?tp_GUID=c78adfaf-87ca-46d1-a15a-0d33583c2797
http://www.steitec.net/ARM-Stamp-Module/ARM-LPC1114-Cortex-M0-Stamp.html
http://ics.nxp.com/lpcxpresso/
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Numaan Chaudhry
over 13 years ago
Thank you for the replies guys, really appreciate it
I'm actually looking to connect a CMOS image sensor to it (a small one - probably about 10mm x 3mm) and then to store the capture on some flash (and transfer off via USB later).
Perhaps taking a step back, do you think the M0 is still the best option for this?
Many Thanks
Regards,
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 28th February 2012 at
It depends on what type of data processing your need to run on the microcontroller.
The Cortex-M0 is well capable of doing general data processing. But if you want to handle image data compression, you might want to use Cortex-M3 for additional instructions on MAC, hardware divide, bit field processing, etc. Or you can even use Cortex-M4 if you want to have faster DCT (it can run faster due to the SIMD feature). The CMSIS DSP library can run on Cortex-M0, Cortex-M3 and Cortex-M4.
regards
Joseph
Cancel
Vote up
0
Vote down
Cancel
