Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
FFT and IFFT using CMSIS DSP library, q15 fractional format
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
jeremy plantier
over 13 years ago
I am currently trying to use the CMSIS DSP library to implement DSP functionality, by doing FFT or IFFT.
I don't have an embedded Floating point Unit, thus I would like to use the fixed q15 fractional format.
By reading the CMSIS documentation html page, it is specified that the FFT/IFFT output format is different from the input one...
For example, for a FFT length of 256, the input format is q15 (1.15) and the output format is 9.7. With 8 bits to upscale.
If I want to perform an FFT and directly fllowed by an IFFT, I have to convert output FFT data which are in 9.7 into a q15 for IFFT Input format...
My question is, from my understanding, the conversion from q15 to 9.7 or the reverse, would be just done by a simple shift of 8 bits...?
But, I guess that data may be lost between each conversion...?
It is very confused to me...
Could someone help me ...?
Thanks!
PjEmY
jeremy plantier
over 13 years ago
Note: This was originally posted on 18th June 2012 at
http://forums.arm.com
Thank you isogen74.
Actually, I performed what I wanted latter during the last week.
My problem was just to perform the right up scalling before sending data to the DAC. I am currently using the Q15 fractional format because it is the only SIMD instructions optimized format (without FPU use) available in the DSP CMSIS library.
Now I have to implement Filtering (FIR) functions to avoid the resulting additional noise which appears after FFT/IFFT.
Thank you again for your help!
[size=4]
[/size]
Cancel
Vote up
0
Vote down
Cancel
jeremy plantier
over 13 years ago
Thank you isogen74.
[size=4]
[/size]
Cancel
Vote up
0
Vote down
Cancel
