Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Performance Counters on ARM1176JZF-S
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Andreas Abel
over 13 years ago
Note: This was originally posted on 14th August 2013 at
http://forums.arm.com
I have a question about the performance counters on an ARM1176JZF-S. Does the event 0xB count L1 or L2 data cache misses?
Martin Weidmann
over 13 years ago
Note: This was originally posted on 19th August 2013 at
Couple of thoughts...
You running bare-metal? As you can't typically access the PMU directly from user space under Linux.
You should probably make "c" and/or a volatile, even at a low optimization level the compiler might eliminate your code otherwise.
I'd suggest taking a look at the assembler code the compiler has generated, to make sure it's what you expected.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
