Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
unexpected segmentation fault changing pc register with branch
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Davide Quarta
over 13 years ago
Davide Quarta
over 13 years ago
Note: This was originally posted on 15th May 2013 at
http://forums.arm.com
As far as I know GDB cannot access those registers.
I'll ask my supervisor if he has access to a good JTAG debugger (probably we could have one lingering around in the department...)
and will write here what are the values of IFSR/IFAR.
p.s. I've checked the memory mapping on
/proc/$pid/maps
and it says that it's correctly allocated with permissions
rwxs
mapped on "
/dev/zero (deleted)
Thank you for your kind reply!
Cancel
Vote up
0
Vote down
Cancel
Davide Quarta
over 13 years ago
thanks all for the reply!
i missed this piece of information:
http://blogs.arm.com/software-enablement/141-caches-and-self-modifying-code/
(studied ARM architecture in two days as much as i could)
flushing the cache solves the problem.
best regards,
D.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
I'm not a GDB expert, but can you get it show you the IFSR and IFAR values? These are the Instruction Fault Status and Instruction Fault Address registers respectively. They are how the processor reports why instruction fetch failed (which is what I'm guessing is happening). Couple of possibilities....
* The memory just isn't mapped (seems unlikely as you've just mapped it, but it's possible you made a mistake)
* The mapped region is marked as eXecute Never (XN), meaning any attempt to execute the address will fail
* Access flag (AF bit) in the descriptor has not been set by the kernel yet.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
You could always printk the registers in the segfault handler.
Cancel
Vote up
0
Vote down
Cancel
