Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
can coprocessor instruction be produced by compiler from c code
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
rensheng yang
over 13 years ago
Note: This was originally posted on 18th April 2013 at
http://forums.arm.com
can accessing coprocessor instruction be produced by compiler from c code?
except float point instructions?
such like drain write buffer instruction?
any docs describe detail of this?
rensheng yang
over 13 years ago
Note: This was originally posted on 19th April 2013 at
i know this feature, named register.
i mean compiler translate c code to arm instructions. except this extension of c code added by specific compiler, can normal c code produce instructions like 'MCR'?
etc, we write
int a;
int b;
int c=a+b;
this will translate to load and modify instructions. or we can use hard-float to control translate to float instructions.
how we can control coprocessor instructions produced from normall C code express?
i think usually c code is used for moving data, so may not produce control instructions, is this right? any theory?
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
Note: This was originally posted on 22nd April 2013 at
What is your goal here? Is it
a: to make the compiler emit certain coprocessor instructions? (If yes, please give an example)
or
b: to make sure the compiler *does not* emit any coprocessor instructions? (If yes, why?)
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Which compiler?
If you are using armcc, I'd probably use the "named register" feature. This lets you declare a variable and tie to a coprocessor register (or other kind of register). Then whenever you access the variable the compiler will generate suitable coprocessor instructions. So:
egister unsigned int cp15_control __asm("cp15:0:c1:c0:0");
This ties the variable to the coprocessor register "cp15:0:c1:c0:0".
http://infocenter.arm.com/help/topic/com.arm.doc.dui0491i/CJAHJDBG.html
I believe GCC has a similar feature, but not sure of the syntax.
Cancel
Vote up
0
Vote down
Cancel
