Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
wrong cycle timing of instructions on ARM11
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
chandrakala reddy
over 13 years ago
Note: This was originally posted on 4th February 2013 at
http://forums.arm.com
Iam using RVDS3.0 for ARM11. some of the instructions are not executing in the time specified by the ARM documentation. for example, according to ARM documents, SMLAD instruction has to take 1 cycle for execution and 2 stalls if the result is immediatly used. but in real time, it is taking 2 cycles for execution. is it a bug on RVDS3.0 or am i missing any thing here. can any one please help me out.
Regards,
Chandrakala
chandrakala reddy
over 13 years ago
Thanks for the reply. there is no register dependency in the code.
Following is my code
SMLAD r0, r1, r2, r3
SMLAD r4, r5, r6, r7
SMLAD r8, r9, r10, r11
SMLAD r12, lr, r1, r6
Is there any issue with the code?
Regards,
Chandrakala
Cancel
Vote up
0
Vote down
Cancel
chandrakala reddy
over 13 years ago
How can i measure exact cycles for ARM11. Is there any way to do that. Has RVDS latest versions solved this problem. Are there any simulators to measure exact cycles.
Regards,
Chandrakala
Cancel
Vote up
0
Vote down
Cancel
chandrakala reddy
over 13 years ago
Thank a lot for the replies. I will use hardware for profiling.
Regards,
Chandrakala
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Couple of possibilities....
* You could just be measuring it incorrect - you haven't given any details of how you are doing this
* It could be a register dependency on one of the inputs
* It could be something like a cache or TLB miss.
I would have thought the second one is the most likely.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
No, the later versions of RVDS didn't include any more accurate (cycle wise) models. You'd have to use real hardware to get accurate results.
Cancel
Vote up
0
Vote down
Cancel
Chris Lamb
over 13 years ago
Are you using the models of the ARM11 CPUs delivered as part of RVDS3.0?
If so, they are based on ARMulator models which stopped being cycle accurate
after v5. Some v6 instructions had approximate cycle counts added, but the complexity
of the pipeline meant that ARMulator could only provide a static calculation. As a result,
none of the v6 instructions in a model can be relied upon to provide a correct cycle
count.
Cancel
Vote up
0
Vote down
Cancel
