Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
SMC instruction
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
SMC instruction
Dm Sh
over 13 years ago
Note: This was originally posted on 22nd January 2013 at
http://forums.arm.com
Good day.
I have a question - where I can get the #immediate value (4bit) in Secure Monitor Exception Handler, when called SMC instruction with non zero parametr - #imm-4 ?
Don't found this value in any registers.
From ARM documentation.
SMC
Secure Monitor Call.
Syntax
SMC{
cond
#imm4
where:
[i]imm4
[/i]is a 4-bit immediate value. This is ignored by the ARM processor, but can be used by the SMC exception handler to determine what service is being requested.
Thanks.
Peter Harris
over 13 years ago
Note: This was originally posted on 27th January 2013 at
Bear in mind that the SMC instruction is used to switch worlds, so you tend to get an address in the "other world's" virtual address map in LR, which in many cases may not be the same as the currently running software. Direct access of the address in LR is therefore unlikely to do what you want - it may well page fault, or at least return utterly unrelated data.
This generally makes it very hard to use this feature of the SMC instruction; at least it makes it more hassle than it is worth - in most cases putting a constant in a register by hand as part of the cross-world smc call API is much easier.
HTH,
Iso
Cancel
Vote up
0
Vote down
Cancel
sandemuk 01
over 13 years ago
The immediate value passed with the SMC instruction can be retrieved by reading back the SMC instruction opcode. The address of SMC instruction can known from the link register of monitor mode. Consider the following code sequence:
IA Instructions
0x840 i0
0x844 i1
0x848 SMC #10
0x84C i3
where IA is the instruction address
When the SMC instruction is executed, a software exception is generated changing the CPU state with LR_mon/R14_mon getting updated with 0x84C (basically address of SMC instruction+4 irrespective of whether the SMC was executed in ARM or Thumb mode). So in the monitor exception handler, we can read back the SMC instruction opcode and extract the immediate value in the following way:
... initial code for monitor handler....
LDR r0, [r14, # - 4]
AND r0, r0, #0xF
(The immediate value is encoded in bits[3:0] of SMC instruction for both ARM and Thumb encoding)
Hope this helps.
Cancel
Vote up
0
Vote down
Cancel
