Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Switch to Non-Secure State During Boot Sequence
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Geary Sutterfield
over 13 years ago
Note: This was originally posted on 2nd January 2013 at
http://forums.arm.com
According to the specs, after a reset, a processor with the Security Extensions boots into secure mode. I thought I read somewhere that if the TEE isn't initialized, then the REE will be loaded and continue to run in secure state. Is that correct? If a switch is done to non-secure state before the REE is loaded, then how is that done? Is there ALWAYS some code present in the boot sequence to make that switch, even if there's no TEE? This question came up while I was discussing hypervisor mode with a colleague, and we found that hypervisor mode was not available while in secure state. To run using the Virtualization Extensions, the processor would have to be in non-secure state. So that seems to imply that a switch to non-secure state must be done at some point. But we didn't understand how that was done if an OEM didn't implement a TEE.
A related question: Do the processor manufacturers implement a TrustZone enable/disable fuse or switch? I didn't see anything in the ARM processor specs that described a global enable/disable TrustZone hardware switch. If there is such a switch, that would be another way to enter non-secure mode at boot time without additional state switching code.
Thanks for any insight into how this works.
Martin Weidmann
over 13 years ago
Note: This was originally posted on 3rd January 2013 at
It depends on which part/board you buy.
Most of the parts I've seen - you're correct. The silicon vendor provides the Secure world code (initial boot rom, firmware, secure os). This code drops into the Normal world, which is when your code runs. You see this on things like the Beagle board.
This is no universal. So for example if you buy one of ARM's Versatile boards, that gives you full access to both worlds.
Similarly, I suspect that if you are a preferred partner OEM of aforementioned silicon company then you get access to secure world (or an API to have their code load your API).
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
