Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Re-Entrant and nesting of low priority Interrupts on Cortex M4
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Mangesh Jadhav
over 13 years ago
Note: This was originally posted on 4th December 2012 at
http://forums.arm.com
Hi All,
I have tried to implement Re-Entrant and nesting of low priority Interrupts on Cortex M4 even if NVIC does not allow this feature.
I am using Freescale's MK60FN1M0VLQ12 processor.
I am trying to implement logic such that NVIC can serve any interrupt irrespective of its priority.
For that i have implemented following logic -----
1 When interrupt occurs , NVIC pushes frame of particular registers to stack ( r0,r1,r2,r3,r12,LR,PC,XPSR - for non floating point execution ). In IRQ Handler, i have
acknowledged the interrupt and then I have pushed dummy frame to stack which contains Reset Value Of XPSR, Address of MY ISR Routine, Original LR, R12 = 0,R3 = 0,
R2 = 0, R1 =0, R0 =0. Then i have used
(BX LR)
to return from handler.
2. So when core returns from handler it will pop dummy frame and will go to MY ISR routine.
3. In MY ISR routine i have done my stuff and then load the registers r0-r4 ,r12, LR,XPSR and PC with original values from stack frame pushed by NVIC.
Now i am able to return successfully to point from where interrupt occurred. Therefore now I am able to nest low priority interrupts even if NVIC executing higher priority interrupt.But sometimes processor goes to Hard Fault Exception.
After that i have implemented same logic for floating point execution in which I have added floating point registers S0 - S15 and FPSCR. But still processor goes to hard fault exception once in a while.
So can anybody suggest what did i miss?
OR has anybody implemented the nesting of low priority interrupts on CORTEX-M core.
Basically my purpose is to serve any interrupt as soon as it occurs irrespective of its priority which can be done in
ARM7
Thanks !!!
Mangesh Jadhav
over 13 years ago
Note: This was originally posted on 6th December 2012 at
Hi Joseph ,
Thank you very much for your reply !!
Yes , What you are saying is correct but I just forgot to mention that only one interrupt is active. so no other interrupt will
pre-empt this interrupt. Also I have restored original XPSR value when returning from ISR. So do you think that it will cause the problem ?
I think the other way to nest the interrupt is to use BASEPRI. I have written a value in BASEPRI in thread mode and Handler mode. but it is not reflected in it. So Is there other way to write value in BASEPRI or we have to enable some other register to write in BASEPRI.
Regards ,
Mangesh Jadhav
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 5th December 2012 at
Maybe problem with nested interrupt scenario?
If your interrupt is not the lowest priority, it might have pre-empted another interrupt.
After your nested ISR finished, it resume the interrupted lower priority ISR.
At the end this execute an exception return with IPSR=0, which could triggered the HardFault.
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 7th December 2012 at
Another possible issue is non-zero ICI bits in xPSR when returning to an instruction that don't have ICI.
But it is difficult to guess what is going on without doing some single stepping...
You can write to BASEPRI as long as the code is running in privileged state.
Joseph
Cancel
Vote up
0
Vote down
Cancel
