Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Source code level debugging on Fast Models
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
James White
over 13 years ago
Note: This was originally posted on 27th November 2012 at
http://forums.arm.com
I'd like to know how I can enable source code debugging with the Fast Model simulator. It allows me to load source code directories, but I don't seem to be able to load any source code files. Does it only enable debugging of actual component code, or can I not also debug what I run *on* the model itself, e.g. application/OS kernel code? Any pointers would be really appreciated.
James White
over 13 years ago
Thanks for your reply! I run Linux (Ubuntu) so I guess it is supported ;-)
I can launch the model debugger when running sgcanvas. So that part works. I can inspect memory and different components. However, I want to do down to instruction level debugging, e.g. I want to be able to see the ARM instructions that are executed on the CPU (eg assembly code). When I try to add source files, e.g. .asm or .S files, then they do not show on the window for adding source files.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Note: This was originally posted on 28th November 2012 at
Ahh, ok - I think I understand what you're doing.
To do source level debug of the code running on the ARM processor you will need debug data. This is data that the build tools generate so that a debugger can map the source level statements to the generated assembly code. Debug data is held within the objects (.o), and later the linked image (.elf/.axf).
First check that you are compiling your code with debug data. If you're using armcc/armasm this means passing "--debug" or "-g". For GCC I think it's "-g".
Next, how are you loading the code/data into the simulation? Raw binary or image (.axf/.elf)?
If it's a raw binary you'll need to separately load the debug data. To do this go to File --> Load Application (Debug Info Only) and select the image being used.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
You can debug the ARM code running in the simulation (via CADI - using RVD, DS-5, Model Debugger, etc...), or the model code itself (using Visual Studio or GDB). Which do you want do?
Debugging both at once can cause problems, as the ARM debugger's connection to the model may time out while you debugging the model itself.
In terms of the debugging the model source, there is a button in the Fast Model tools GUI that should launch it for you (assuming you're using a support platform).
Cancel
Vote up
0
Vote down
Cancel
