Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
AHB Slave and Master standard and optional pinsets
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Leonard Lim
over 13 years ago
Note: This was originally posted on 30th November 2012 at
http://forums.arm.com
I have a problem finding out which of the AHB slave-side pinsets are optional and which are standard from the specification.
Is this different than AHB-Lite, where the lsave-side interface pinset are determined as in figure 1-3, page 1-4 AHB Lite specification
Even in the specification for AHB, this is not clearly defined.
The nearest I could get comes from figure 3-23 on page 3-45.
The diagram seems to suggest that most of the slave-side signals are required, except for HMASTER, HMASTLOCK and HSPLIT, which are only required for split capable slaves.
However, there are some confusion in this diagram
a) HREADYin is missing as an input into the slave
HMASTLOCK has to do with the ability of the slave to perform out of order transaction, and not whether a slave is split capable or not
c) example design as explained below paints a different picture.
In the AHB example designs, a default slave, only has HTRANS and HSEL as its input and HRESP and HREADY as output. Meanwhile a static memory interface contains many more AHB signals.
Does this mean that all slave-side signals are optional, depending on the implementation of the slave, or is there a list of required end-point slave signals?
Please help, I am very confused!
Source:- Example AMBA system
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0170a/index.html
Source:- AHB specifications
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ihi0011a/index.html
Source:- AHB-lite
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ihi0033a/index.html
Colin Campbell
over 13 years ago
I always understood that all inputs are optional, all outputs are mandatory.
Looking just at slaves, the default slave inputs you list (plus HCLK and HRESETn) are the bare minimum you would need for any functionality, then you could consider HADDR, HWRITE and HWDATA as probably the next most common set of inputs the slave would require for basic functionality. All other inputs just add to the information you "might" be able to use.
However if you are using automatic tools to "stitch" together RTL components, these might require full AHB port lists so that there is always a pin to connect to (just a thought !)
JD
Cancel
Vote up
0
Vote down
Cancel
Colin Campbell
over 13 years ago
JD
Cancel
Vote up
0
Vote down
Cancel
