Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARM PMU - Event 0x56 - No instructions for issue (A8)
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Prabindh Sundareson
over 13 years ago
Note: This was originally posted on 30th October 2012 at
http://forums.arm.com
[font=Arial][size=2]I am using peemuperf (
https://github.com/prabindh/peemuperf/blob/master/README.md
) to get various cache profile results from ARM PMU, and some specific EMIF counters available in TI processors. I am currently looking at one of the A8 processors. In ARM Performance monitoring unit, the SEL field (event ID) of [/size][/font]EVTSEL register can be used to select the event ID.[size=2] In this, 0x56 is defined to indicate "[/size]0x56 ==> Increment for every cycle that no instructions are available for issue[size=2]". [/size]
[font=Arial][size=2] [/size][/font]
[font=Arial][size=2]With the goal of finding cycles lost because CPU is waiting for I-cache miss and refill to be available, when 0x56 is used, I see some correlation, but with below issues:[/size][/font]
[size=2]- [/size][font=Arial][size=2]At no-load conditions (no UI or other application, CPU load being negligible), this counter gives cycles equal to that of CPU clock speed. In a 720 MHz processor, I see 720M cycles. This does not match with the description. What is the explanation ?[/size][/font]
[size=2]- [/size][font=Arial][size=2]At high loads, there is a more meaningful number coming out of the counter, but still it appears to be high, that indicates to me that this cycle count is not just that of CPU waiting for I-cache refills.[/size][/font]
[font=Arial][size=2]Is there a better explanation/ validated results available ?[/size][/font]
Peter Harris
over 13 years ago
> What is the size of the refill here
Cache line size.
> Also, what is the lowest level of cache referred to here "" is it L1 or L2 ?
Hmm good question. I assume the level of cache closest to the core (lowest number, but I'm not entirely sure). However there is an architectural counter (0x1) which counts L1 I cache refills if you want to count instruction cache misses.
> is there a way to determine the number of line requests made to the SOC from the cache controller
Look at the L2 cache refill counters, if available on your platform.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Cache line size.
Cancel
Vote up
0
Vote down
Cancel
