Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
MCPS analysis for ARM9,ARM7 and cortex-A8
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Praveen Kumar
over 13 years ago
Praveen Kumar
over 13 years ago
Note: This was originally posted on 19th October 2012 at
http://forums.arm.com
I have set the same CPU frequency for all 3 set ups.
Cancel
Vote up
0
Vote down
Cancel
Praveen Kumar
over 13 years ago
Note: This was originally posted on 22nd October 2012 at
I am using the targets that have been shipped with the RVDS4.1 (ARM926EJS, ARM1136JS).
I have taken care of Memory mangement(using scatter ,init_cache files) , branch prediction(simulator settings) for ARM11, ARM9 but not for Cortex-A8.
In cortex-A8 I have only used the branch prediction settings(--cpu).If you have any memory management related files that could help me simulate the cycles results that would be helpful.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
[color=#222222][font=arial, helvetica, sans-serif][size=2]> Can any one please explain me the reason of this behaviour [/size][/font][/color]
[color=#222222][font=arial, helvetica, sans-serif][size=2]ARM11 is generally faster for compiled code, but it is easy to write assembler for an ARM9 and have it run slower. [/size][/font][/color][color=#222222][font=arial, helvetica, sans-serif][size=2]Without looking at your code it is hard to say exactly why. My guess is that you have some tight loops in your assembler which don't play nicely with the ARM11 branch predictor.[/size][/font][/color]
[color=#222222][font=arial, helvetica, sans-serif][size=2] * Always try and make sure you have two other instructions in between the flag setting operation and the use of the condition in a branch.[/size][/font][/color]
* Don't branch to a branch instruction, the second one will always fail to predict.
[color=#222222][font=arial, helvetica, sans-serif][size=2] * ARM11 has a two cycle load-use penalty, so don't use loaded registers on the next instruction or you will get stalls.[/size][/font][/color]
You also don't say what your benchmarking setup in terms of the three CPU frequencies are. ARM11 will probably be slower than an ARM9 at the same frequency "on average" because the pipeline is longer. However the longer pipeline means it has a significantly higher top clock speed which is where much of the performance comes from. Cortex-A8 is a dual issue machine, so that should be faster at the same frequency.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Note: This was originally posted on 21st October 2012 at
You don't mention what the platforms are, are much about how the tests were run.
For example, if you're using the models shipped with RVDS these are NOT cycle accurate. So any figures for the ARM11/Cortex-A8 you get will be misleading at best, meaningless at worst.
How are you setting up memory management? The more advanced the processor the bigger the impact of not (or incorrectly) setting up memory management. With caches, branch prediction, etc... set up correctly, they might conceivably be worse than the ARM9.
Cancel
Vote up
0
Vote down
Cancel
