Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
exclusive access in Origen board
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Lee Wang
over 13 years ago
Note: This was originally posted on 16th September 2012 at
http://forums.arm.com
hi, i'm making a little distributive calculation project on Origen board almost totally based on CortexA2x2_RTSM example downloaded from this site.
everything goes fine, until lockMutex realization. strex instruction always returns 1, even though, it writes value to memory. seems that monitors didn't tag physical address as exclusive access after ldrex instruction, but mmu was turned on fine and memory range that contains mutex-values was "normal sharable" (this part was taken totally from CortexA2x2_RTSM).
please. help me to figure out what the problem is.
Martin Weidmann
over 13 years ago
Note: This was originally posted on 17th September 2012 at
Best guess would be that the core is trying to use the Global Monitor, and that there isn't one. So the "exclusive" bus accesses always return failure (technically OKAY instead of EXOKAY).
So the question would be why is the core trying to use the Global Monitor.... Some things to check:
* Is the L1 data cache turned on? It needs to be.
* Are the ACTLR.SMP and ACTLR.FW bits set? And is the SCU enabled?
* You said the region is marked as normal+shareable, is it also write-baclk/write-allocate
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
