Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
How to avoid reference to fplib functions
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Michal Szymanski
over 13 years ago
Note: This was originally posted on 2nd October 2012 at
http://forums.arm.com
I'm building objects for armv5 with option -fpu=softvfp. All objects are combined to .a library. It seems that compiler puts to my code helper functions such as __ARM_scalbn and __aeabi_lasr. The problem is, that these functions are not hard-coded into my .a lib, references are needed during linking. For some reasons I would like to avoid such behavior and create "stand-alone" .a library, which can be used without fplib and other helpers. In other words, i would like to build-in these functions into library. Is that possible?
MSZ
Michal Szymanski
over 13 years ago
Do you need fp? If not you could use "--fpu=none"
I need software floating point. But that's tricky, because during linking I don't have access to helpers library. I will give example: library includes function for conversion from float to fixed-point - that's the place where __ARM_scalbn is used. I want to make this function inlined (or something like that) into code. End-user of library should be unaware which functions are hidden under library.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Note: This was originally posted on 3rd October 2012 at
If you only need to hide this from your end users you could statically link the fp helper library into the binary you distribute.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
