Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
lpc13xx UART
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
lpc13xx UART
Frosty Frosty
over 13 years ago
Frosty Frosty
over 13 years ago
Note: This was originally posted on 10th September 2012 at
http://forums.arm.com
yap I have catch it, was the problem with periferial clock settings. But it takes anothes 2 days to understand what is wrong, because I'm using not keil (uVision) but IAR, ;[
thanks for advice anyway.
Cancel
Vote up
0
Vote down
Cancel
Dhaval Solanki
over 13 years ago
Note: This was originally posted on 8th September 2012 at
Debugg the code and with the help of "UART window" just check if your code works properly. (Debugg using the simulator of your IDE. UART window may be present in the simulator (I don't know what IDE you are using but i use Keil and have a UART window.)
Check the values of all the clocks generated (system clocks, peripheral clocks and baud rate).
If everything is working fine in your code, then check the hardware of your board. Check if the rs232 driver IC is working fine. To ensure this, perform following actions:
1. Just short the Rx & Tx pin (on PC side i.e. input side). Transmit some characters from the terminal and check if you are getting the same on input terminal.
2. If thats ok, then short the Rx & Tx pins (on the CPU side) and transmit some characters and check if you are getting the same on input terminal.
If you haven't found anything yet, then its time to check your serial cable. Just check if the connections are proper. Invert the Rx and Tx of the cable at one connector. and repeat the above steps.
you'll definitely find out where the problem lies.
All the best
Cancel
Vote up
0
Vote down
Cancel
