Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
control is not returning to assembly when tried return(0) in main of test case
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Lokesh Kumar
over 13 years ago
Note: This was originally posted on 27th August 2012 at
http://forums.arm.com
Here is my code. As you can see below from C test case main has return and main was called by assembly code by using BL main.
But when I run this test control never comes back to assembly, since main is not retuning control to assembly as it should have done since BL instruction is used.
I do see that main function is getting completed as it's printing it's messages.
Do I need to do something different?
[color=#1F497D]Assembly code is as below :-[/color]
//ARM initialization code
//Call C main function
BL main
MOV r0, #0
MOV r1, #1
LDR r2, =0xffffffff
LDR r10, =0xcab00010
LDR r0, [r10]
STR r0, [r10] ; 0's
STR r2, [r10] ; f's
STR r0, [r10] ; 0's
DMB
Loop
WFI
B Loop
B pass
[color=#1F497D] [/color]
[color=#1F497D][/color]Main function of C code is as below :-
[color=#1F497D] [/color]int main(int argc, char *argv[]) {
loc_puts("INFO: ARM Booted Successfully!\n");
loc_puts("READ to boot space!\n"); return (0);
Lokesh Kumar
over 13 years ago
Note: This was originally posted on 4th September 2012 at
Scott,
Thanks for answering.
How to set stack size so that main function doesn't overwrite return address?
Is there any way to avoid it?
I see in assembly we do give option like below
; Heap starts at 1MB in RAM and grows upwards
ARM_LIB_HEAP 0x20100000 EMPTY 0x100000-0x8000
;; Stack starts at the end of the 2MB of RAM
;; And grows downwards for 32KB
ARM_LIB_STACK 0x20200000 EMPTY -0x8000
Is this the correct or I need to modify them?
Please guide me, as I am knew to arm flow.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
Note: This was originally posted on 29th August 2012 at
I suspect a stack problem. Very likely 'main' uses the stack to save/restore the return address. Possibly the saved return address is being overwritten by 'loc_puts' or possibly the stack pointer (sp/r13) is not pointing to valid memory.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
Note: This was originally posted on 5th September 2012 at
The stack pointer (and indirectly the stack size) is usually set by the "startup code". For bare-metal (no OS) cases this can be code supplied by the development environment. The startup code and is also responsible for things like iniitializing global variables, initializing the C library and calling main. You seem to be writing your own startup code and using the ARM compiler (Keil, DS-5 or RVDS). Have you seen this
http://infocenter.ar...h/CHDJGDAD.html
(or the equivalent for your version of the tools)? __main is the ARM library's startup code and is what make use of the ARM_LIB_STACK and ARM_LIB_HEAP areas.
The addresses of RAM suitable for use as stack and heap will depend on exactly what target you are using and will be different from one chip/platform to another.
Cancel
Vote up
0
Vote down
Cancel
