Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Memory alignment while using LDR instruction in cortex A9
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
ANGEL MARY NATHAN
over 13 years ago
Note: This was originally posted on 3rd August 2012 at
http://forums.arm.com
I am facing some problem while trying to load a 32 bit value into a register by using LDR R0 [R1] where R1 is a pointer to a memory location having some value.
when i use the LDR instruction 3bytes are fetched from the location pointed by R1 and the 4th byte is 1byte before the loacation pointed by R1.
I am working on ARM Cortex A9 simulator.
Is it anything related to memory alignment?
How do i solve this?
Thanks in advance
Angel
ANGEL MARY NATHAN
over 13 years ago
Note: This was originally posted on 6th August 2012 at
HI ttfn,
The value of R1(pointer) is 0x403023cd.
Im using CCS V5, In the properties i have chosen cortex R4.
The memory looks like
address 0x403023cc 0x403023cd 0x403023ce 0x403023cf 0x403023d0
value 0x4E 0X4D 0X4C 0X4B 0X48
R1 is pointing to 0x403023cd
when I try loading LDR R0,[R1], the value i get in R1 IS 4E4B4C4D.
Cancel
Vote up
0
Vote down
Cancel
ANGEL MARY NATHAN
over 13 years ago
Note: This was originally posted on 7th August 2012 at
Hai
isogen74,
Thanks for the reply.
So do you mean to say the simulator is not installed properly.
Is there any changes in the settings that i could make to make it treat the unaligned memory properly.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
What is the value of R1 (specifically the bottom bits)? And which simulator are you using?
What you describe sounds like what pre-v6 processors did for unaligned accesses.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Hmm - it looks like the simulator is not correctly handling unaligned loads. Depending on setup I would either expect:
* An alignment fault
* An unaligned access (0x4D, 0x4C, 0x4B, 0x48)
I'd suggest talking to the vendor of the simulator.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Based on the information you've given it looks like a bug in the simulator. The memory access pattern it is performing (accessing memory below the current address in a different word) is not something an ARM core would ever do.
Cancel
Vote up
0
Vote down
Cancel
