Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
CM3 linker issues
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
CM3 linker issues
Abishek Ambrose
over 13 years ago
Note: This was originally posted on 26th July 2012 at
http://forums.arm.com
Found this while doing some asm coding inside c files.
1. CM3 was not able to insert veneer for function symbol + offset. ( BNE FuncName + 184)
//Error: L6416E: Relocation R_ARM_THM_JUMP19 at REL:1 in Section .emb_text from //uhe_dev_HidCustomPackFilter.o cannot be veneered as it has an offset 184 from its target.
2. Linker is trying to create veneer even though the address range is less than 1MB.( BNE FuncName)
// $Ven$TT$S$ FuncName
// 0x000d27cc: f751bbdc Q... B FuncName; 0x23f88 (Diff is less than 1MB)
Major issue:
Procedure to find:
When we compile the BNE instruction with a function symbol (
BNE FuncName
) it compiles successfully .
Linker inserts veneer for this instruction. Now when I change the instruction (
BNE FuncName + offset
) just added offset. And then recompiled and linked only that file . Now it links successfully without any error. But when I see the assembly code it has just taken the old veneer(not updated) without adding the offset .
This error is more critical and difficult to trace it out.
Can somebody help me to solve this issues while linking.
Abishek Ambrose
over 13 years ago
Note: This was originally posted on 27th July 2012 at
I use RVDS 40 build 902.
Thank you
Cancel
Vote up
0
Vote down
Cancel
Alban Rampon
over 13 years ago
Good afternoon Abishek,
Thanks for your report.
Would you please be able to let us know which tool and which tool revision you are using?
I would need that to see where this can be escalated.
Kind regards, Alban
Cancel
Vote up
0
Vote down
Cancel
Alban Rampon
over 13 years ago
I'm sorry if my question sounds a bit stupid, but are you sure this branch supports offsets?
I have looked at example codes and couldn't find any with it...
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0337g/BABBCJII.html
Cheers, Alban
Cancel
Vote up
0
Vote down
Cancel
