Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Cortex-A9 MPCore with L2 Cache Controller (L2C-310)
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Vaibhav Malik
over 13 years ago
Note: This was originally posted on 16th July 2012 at
http://forums.arm.com
On a quick introduction note,
I am working on Cortex-A9 with MPCore configuration where Number of cores is 1. We have L2C- 310 L2 Cache Controller.
[color=#1F497D]This is regarding resolving the issue after enabling L2 cache controller.[/color]
[color=#1F497D]I've followed therecommendation from the L2-310 specification before enabling the L2 Cache.[/color]
[color=#1F497D] [/color][color=#1F497D][A] Invalidate by way, offset0x77c to invalidate all entries in cache; poll cache maintenance register untilinvalidate operation is complete[/color]
[color=#1F497D] [/color][color=#1F497D][B] Write to interrupt clearregister to clear any residual raw interrupts set.[/color]
[color=#1F497D] [/color][color=#1F497D]The following recommendation I havealready taken care in the boot reset code for A9.[/color]
[color=#1F497D] [/color][color=#1F497D][1] Invalidate the data cache (L1)[/color]
[color=#1F497D] [/color][color=#1F497D][2] Invalidate the SCU duplicatetags[/color]
[color=#1F497D] [/color][color=#1F497D][3] Invalidate the L2-310[/color]
[color=#1F497D] [/color][color=#1F497D][4] Enable the SCU[/color]
[color=#1F497D] [/color][color=#1F497D][5] Enable the data cache[/color]
[color=#1F497D] [/color][color=#1F497D][6] Enable the L2C-310[/color]
[color=#1F497D]I enable MMU along with [5]above. For me as soon as I enable the L2 cache [6], the processor startgenerating aborts or sometimes it hangs. If I don't enable L2 Cache (just byskipping [6]), everything seems to be working fine.[/color][color=#1F497D] [/color]
[color=#1F497D]As an alternative steps ortrials, I have tried draining STB, EB, LRB, and LFB after invalidating theL2-310. This also doesn't help. I am also making sure that the L2-Cache isdisabled whenever I attempt any management operation such as invalidate, syncetc. [/color]
[color=#1F497D]There are registers such asauxiliary, Tag RAM Latency, Data RAM Latency, pre-fetch, and power controlregisters which I have working with valid values. [/color]
To me, it looks like I have followed recommendations as suggestion in specification. [color=#1F497D]I am also making sure to set the data endianne[/color][color=#1F497D]ss for L2 Cache controller as per my firmware build. [/color]
[color=#1F497D][Q1] Is there anything I have missed above?[/color]
[color=#1F497D][Q2] Is there any specific page table entries I have to mark explicitly with TEX and C and B (considering outer cache)? I am for the moment left my page table entries as what I have for the L1 Cache (as skipping [6] above leaves the L1 cache enabled and everything works fine). If yes, how does it should be for L1 and L2 Cache together where one region attributes are reflected from both inner and outer cache attributes?[/color]
[color=#1F497D] Vaibhav[/color]
[color=#1F497D]
[/color]
Peter Harris
over 13 years ago
You mention this is an SMP system, you are not trying to enable the cache twice in parallel from multiples cores by and chance are you? It is obviously a shared resource, so you will usually need to bootstrap CPU0, init the L2, and then start up the other cores.
My only other thought is to check you have barriers in all of the appropriate places to ensure you are not getting memory accesses leaking across critical instructions.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
