Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
AMBA AHB
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
AMBA AHB
sandesh shetty
over 13 years ago
Note: This was originally posted on 10th July 2012 at
http://forums.arm.com
I have been working on AMBA AHB slave design. I have come across a deadend.
The problem is as follow.
When a master inserts a busy transaction indicated by the HTRANS as 01. What should be the condition of HREADY from the slave.
The spec says that the slave should provide a non zero wait state to the busy inserted byt the master.
However what should be the status of HREADY when the slave itself is busy and is not able to complete the previous transaction.
Kindly help me with this if possible.
Regards,
sandesh shetty
Colin Campbell
over 13 years ago
Note: This was originally posted on 12th July 2012 at
Sandesh,
If a slave is being asked to do something (a nonseq or seq) access, it can add wait states using HREADY during the data phase for those transfers,
But if the slave is not being asked to do anything (so busy or idle transfers), there is no reason for the slave to need to add wait states, so the HREADY signal must be driven high for the data phases of those transfers.
When you say "the slave itself is busy", what is it busy with such that it can't just check HTRANS to see if it just needs to return a default HREADY=1 response for the idle/busy transfer request, or hold HREADY=0 for the nonseq/seq transfer request ?
JD
Cancel
Vote up
0
Vote down
Cancel
Colin Campbell
over 13 years ago
Sandesh,
JD
Cancel
Vote up
0
Vote down
Cancel
