Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Pin Interrupt Enable/Disable Confusion
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
thomas ketnawang
over 13 years ago
Note: This was originally posted on 11th June 2012 at
http://forums.arm.com
Hello, at the moment i study the LPC11U1x manual(Cortex-M0) and i found some very confusing thing, in the GPIO interrupt registers to enable a rising edge or level interrupt i can set a bit in IENR or delete a bit to disable the interrupt. but the CIENR disables a interrupt by deleting the corresponding bit in IENR and again there is SIENR that only set the corresponding bit in IENR
ISEL Pin Interrupt Mode register: Selects if edge or level sensitive
IENR Pin Interrupt Enable: Enables rising edge/level interrupt
0 = Disable rising edge or level interrupt.
1 = Enable rising edge or level interrupt
SIENR Set Pin Interrupt Enable
0 = No operation.
1 = Enable rising edge or level interrupt.
CIENR Clear Pin Interrupt Enable
0 = No operation.
1 = Disable rising edge or level interrupt.
IST Pin Interrupt Status register
1 = (edge-sensitive): clear rising- and falling-edge detection for this pin.
So if i have a rising edge interrupt i can set him over IENR or SIENR
if i wont to disable the interrupt i can do that by IENR or CIENR or IST
so IST my make sense but why CIENR and SIENR
is this for compatibility with other cortex`s?. did i understood it right?
Regards Thomas
Joseph Yiu
over 13 years ago
Note: This was originally posted on 13th June 2012 at
Hi Thomas,
Yes, the GPIO SET0/CLR0, SET1/CLR1 are the same. Each GPIO pin can be used by different tasks in the software and this arrangement avoid any conflicts caused by read-modify-write sequences.
Hope you find the book useful. :-)
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Hi Thomas,
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
