Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Nested Interrupt CM3
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Nino Caruso
over 13 years ago
Note: This was originally posted on 29th May 2012 at
http://forums.arm.com
Hello everyone,
i just want to know how does nesting interrupt work on Cortex M3.
Register PRIMASK, BASEPRI and FAULTMASK are usefull if i want to ignore ,when occurs, certain interrupt (by setting a priority level threshold) ignore= interrup not accepted, interrupt not nested
Register like SETENA enable or disable specific interrupt ( by # )
When the processor is handling an exception and comes an interrupt that has upper priority level, the current exception is nested (save register etc etc ) and the new exception is executed. If the priority of the new interrupt is lower , the NVIC will not nest the interrupt, it will be ignored.
is correct what i've understood? is there something that i miss?
thank you in advance
Nino
ps i'm sorry for my bad english
Nino Caruso
over 13 years ago
Note: This was originally posted on 4th June 2012 at
-"In such case, the pending status of this interrupt will be set"
in particular : where the pendig status is set, for an internal interrupt if the SETPEND is only for external interrupt?
similarly for register SETENA/CLRENA, how can i enable/disable internal interrupt if the registers(SETENA,CLRENA) are associated only to external interrupt?
-How can the CM3 determine the priority of an internal interrupt that is programmable if there is not a priority level register associated to it?
(ex: BUS FAULT exception #4 has a priority level programmable, where cm3 find it?)
Cancel
Vote up
0
Vote down
Cancel
Nino Caruso
over 13 years ago
Note: This was originally posted on 6th June 2012 at
why there are 2 registers (SETENA and CLRENA) when i can enable/disable external interrupt by using one? (bit =1 external interrupt enabled , bit= 0 ext. int. disabled)
i know that writing 1 in reg CLRENA means that clear to 0 the respectively bit in the SETENA reg, but with one reg it works better
another question , how nvic schedule the pending interrupt (external or internal ) by priority?
thank you
Cancel
Vote up
0
Vote down
Cancel
Nino Caruso
over 13 years ago
Note: This was originally posted on 11th June 2012 at
WFI wakeup behavior :
when an interrupt arrives it's priority must be higher than "current privilege level",BASEPRI and the mask registers, than it wakeup the processor that execute the handler. Else if the interrupt will not be accepted due the priority it will not wake up the processor, in this case it will be set as pending? is there a possibility that the interrupt wakeup the processor but will be set as pending?
Similar questions for WFE wakeup behavior, is there a possibility that a event wakeup the processor but it will be set as pending? if yes,where is it set? in the register SETPEND?
thank you
Cancel
Vote up
0
Vote down
Cancel
Nino Caruso
over 13 years ago
Note: This was originally posted on 12th June 2012 at
Questions about WICSENSE,WICLOAD,WICMASK.
both WICMASK and WICSENSE are used to indicate that the WIC must wake up in response to the corresponding WICINT signal, but in particular WICSENSE what does it do?
WICMASK comes from the core of CM3(from NVIC) to WIC but what make me confuse is that WICSENSE comes out from the WIC to i don't know where.
How can WICLOAD is usefull(togheter WICMASK) to enable certain interrupt or event to cause a wakeup?
WIC works only when there is deep sleep, normal sleep don't causes power down to the nvic like deep sleep, right?
Thank you in advance
Cancel
Vote up
0
Vote down
Cancel
prasant behera
over 13 years ago
Note: This was originally posted on 5th June 2012 at
The pending status for internal exceptions are set in System Handler Control and State Register.
The priority of internal exceptions can be configured in System Handler Priority Register1, 2,3
Please go through the CM3 System Handler Priority Register1, 2, 3 and System Handler Priority Regsiter descriptions for the usage
Thanks and Regards,
Prasant
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 30th May 2012 at
Hi Nino,
The use of "ignore" is possibly not the best word.
If an interrupt occurred, but:
- the PRIMASK or FAULTMASK or BASEPRI is set, which result in blocking the interrupt, or
- the Cortex-M3 is already running another interrupt handler with higher or same priority
The processor will not accept the new interrupt.
In such case, the pending status of this interrupt will be set, and the processor will process it later if:
- the PRIMASK / FAULTMASK / BASEPRI is cleared, or
- the processor finished the current executing Interrupt Service Routine (ISR) and exited the handler, which result in current priority level change.
In overall, the interrupt request is not lost, but could be delayed by the interrupt masking registers or other interrupt services.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Regarding WFI:
>else if the interrupt will not be accepted due the priority it will not wake up the processor, in this case it will be set as pending?
Yes, correct.
Yes, by setting PRIMASK.
Regarding WFE:
Yes, using the SEVONPEND feature. By setting bit 4 of System Control Register, an event is generate for a new pending of a interrupt, which can wake up the processor from WFE sleep.
Yes, in the pending status register. You can read back the current pending status from SETPEND (NVIC->ISPR) as well as CLRPEND (NVIC->ICPR).
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Hi Nino,
I guess you are working for a company which is a ARM customer? If yes, for these RTL related question please use ARM support. (Please use your work email address so that the support team can identify you). It is inconvenient to answer this kind of questions on a public forum as some information could be confidential. Thanks.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 8th June 2012 at
It is intentional to use two addresses to set and clear the NVIC enable register.
If it use just one address for normal read and write, you need to use a read-modify-write operation to change a bit in this register. During this sequence, if a interrupt happen and the interrupt handler changed another bit in the register, when you resume the read-modify-write, you will overwrite the changes made by the interrupt handler.
The same issue can happen in system with RTOS, where context swtiching can happen in the middle of the read-modify-write, and after the task is resumed it could overwrite the changes made by another task.
By using two register addresses, you only need to have one write to enable/disable a interrupt, without the need to read back the status of the whole register beforehand.
The NVIC has a number of priority level registers for each interrupts. It compare the priority levels of pending interrupt requests against each other, as well as to the current level of the processor. This is done in hardware. If the priority level of a pending interrupt is higher than others (including the current level of the processor), it will signal to the processor core and the processor will suspend current task and start processing the interrupt request as soon as possible.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
