Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Weird interrupt behaviour on Cortex-A8
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jitesh Shah
over 13 years ago
Note: This was originally posted on 4th April 2012 at
http://forums.arm.com
My current configuration is as follows:
Cortex A8 with TrustZone enabled. I have both secure and normal world running. Monitor mode is setup and is working neatly. All exception tables are in place.
FIQs are configured to be trapped in the monitor mode (Bit 2 in Secure Configuration Register - c1, c1, 0, 0 in cp15)
Both IRQ and FIQ are enabled in secure as well as normal world. All interrupts are IRQs except a timer interrupt. Expectation is that, periodically the timer will trigger and trap into the monitor mode.
Now, when I am in the secure world, this works fine. The timer triggers, the hardware is trapped into the monitor mode and the FIQ vector is executed. However, if I am executing in the normal world, the timer interrupt *never* occurs. I haven't done any special setting in the normal world and I don't reckon its required. My expectation was that, irrespective of which world is being executed, the control will go into the monitor mode.
Is my understanding wrong? Shouldn't the hardware trap me into monitor mode from the normal world if the timer interrupt occurs with the above described settings?
Thanks,
Jitesh
Mallikarjun Shivappa Bidari
over 13 years ago
Note: This was originally posted on 5th April 2012 at
Jitesh,
Please make sure, you are verifying it in the FIQ expcetion handler of Monitor mode. The Vector table for the Monitor mode is different.
MVBAR holds the exception base address for the Monitor mode.
Also make sure whether you have enabled Vectored Interrupt bit or not. If SCTLR.VE is 1, then the FIQ exception handler is implementation defined.
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Jitesh,
Cancel
Vote up
0
Vote down
Cancel
