Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Setting 'shareable' attribute in PT entry discard cache policies ?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Sujith K V
over 13 years ago
Note: This was originally posted on 21st March 2012 at
http://forums.arm.com
I am working on Cortex-A8 with MMU Enabled.
I am configuring L1 as Write Through No Write Allocate and L2 as Write Back Write Allocate. Both L1 and L2 caches are enabled.
And the memory attribute is given normal memory and 'shareable' in the page table entry.
Then, When I write to a variable, its also written to memory.
When I change only the memory attribute to 'non-shareable', the variable is written to cache only.
Is shareability attribute means, irrespective of the cache attributes we set, it will be 'write through ??', Or all writes are happening to memory only?
I dont see any other CP15 register settings which can cause this behaviour.
Can anyone help me ?
Regards,
Marcus Harnisch
over 13 years ago
In general, cache policies are defined in the ARM ARM as "wishful thinking". The processor implementation may ignore them under certain conditions.
Declaring a region as non-shareable means that no other master in the system will access that region. From the processor core's perspective it makes no difference whether the actual cache behavior is write-through (as configured) or write back.
Kind regards
Marcus
Cancel
Vote up
0
Vote down
Cancel
Marcus Harnisch
over 13 years ago
Kind regards
Marcus
Cancel
Vote up
0
Vote down
Cancel
