Site
Search
User
Site
Search
User
Forums
Can I map the code/data memory as device memory
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
allen.zhang
over 9 years ago
For example, map the EL3 firmware memory as device memory, What we should concern? Thanks!
+1
Peter Rielly
over 9 years ago
The architecture doesn't allow code to be executed out of device memory so that would be a concern. If you only mean data pages then there is no particular reason this won't work, although it will be slow.
P
Cancel
Vote up
0
Vote down
Cancel
0
allen.zhang
over 9 years ago
in reply to
Peter Rielly
Thanks.
We have to run program as normal memory and IO range as device memory?
What about set the RO/RW/IO range as uncacheable memroy?
What about close MMU to run the el3 firmware?
Cancel
Vote up
0
Vote down
Cancel
0
Peter Rielly
over 9 years ago
in reply to
allen.zhang
IO memory needs to be uncached but Device memory is always uncached so that is cool.
Instructions must be in Normal memory, which can be cached or uncached.
@EL3 with the MMU off *all* data accesses will be to Device memory and *all* instruction fetches will be to Normal memory. The address range doesn't matter.
Cancel
Vote up
0
Vote down
Cancel
