Site
Search
User
Site
Search
User
Forums
INVPC Hard fault exception error
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Cortex-M3
Options
More actions
Cancel
Related
DrWhom DrWhom
over 13 years ago
Note: This was originally posted on 16th July 2009 at
http://forums.arm.com
Using and Arm Cortex M3, the application that is running sometimes will generate a hard fault and deciphering the CFSR register tells me that the following user fault is triggerred.
From the Cortex manual:
INVPC - Attempt to load EXC_RETURN into PC illegally. Invalid instruction, invalid context, invalid
value. The return PC points to the instruction that tried to set the PC.
Not sure where to proceed as the PC is pointing to the line in the exception handler. I am trying to figure out the instruction that triggerred the hard fault. Anybody have any suggestions?
Top replies
HenkvW
over 9 years ago
+1
verified
Hi, I encountered the same problem. It turned out to be a recursive call.
0
guestposter guestposter
over 13 years ago
Note: This was originally posted on 22nd July 2009 at
I don't know. Have you try contact FreeRTOS for support?
Cancel
Vote up
0
Vote down
Cancel
0
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
