Site
Search
User
Site
Search
User
Forums
WFI and cpsid i in ARM Cortex R5
Jump...
Cancel
State
Not Answered
Replies
1 reply
Subscribers
348 subscribers
Views
Users
0 members are here
Cortex-R5
Options
More actions
Cancel
Related
Aswin Sankar
2 months ago
Hello everyone,
I am working on an
ARM Cortex-R5
design where the core operates in
VIC (Vectored Interrupt Controller) mode
and is connected to a custom Vectored Interrupt Manager (VIM) via the dedicated VIC port interface.
Our system architecture requires the bootloader to issue an SoC-level reset to jump into the main application. A strict hardware constraint of this SoC reset is that the Cortex-R5 core
must be in a steady WFI (Wait For Interrupt) low-power state
for the reset signal to successfully propagate throughout the system fabrics.
Before triggering the WFI state, the bootloader's teardown sequence is responsible for disabling and clearing all peripheral interrupts at the VIM level. However, we are observing a strange, non-deterministic behavior depending on when
CPSID I
is called relative to the VIM de-assertion.
The Sequences
Sequence 1 (Fails Intermittently):
CPSID I ; 1. Mask IRQ exceptions in CPSR
; [Code to disable VIM interrupts]
; [Code to clear active VIM flags]
DSB
ISB
WFI ;
Behavior:
The device fails to jump to application because the reset cannot be propagated, which points to the fact that device is not in wfi.
Sequence 2 (Succeeds Consistently):
DSB
ISB
CPSID I ; 3. Mask IRQ exceptions in CPSR
WFI ; <-- Core enters WFI standby consistently
Behavior:
The SoC level reset propagates correctly.
My Questions for the Forum:
Per the
ARMv7-R Architecture Reference Manual
, setting the CPSR
I
bit (
CPSID I
) masks interrupt
exceptions
from branching to vectors, but does not block the architectural
WFI
wake-up event logic. A pending signal on the
nIRQ
line will always prevent or wake the core from a
WFI
VIC Port Handshake:
When the core is in VIC mode and
CPSID I
is executed
first
(Sequence 1), does masking the IRQ inside the CPSR affect or freeze the hardware-level handshake protocol across the VIC port interface?
Ghost Pending Interrupts:
Does clearing/disabling the VIM
after
CPSID I
leave a "phantom" pending event inside the core pipeline? Does the internal interrupt controller of the Cortex-R5 require the CPSR
I
bit to be 0 (
0
) to properly complete a de-assertion handshake over the VIC port?
What exactly happens inside the Cortex-R5's interrupt pipeline state machine when
CPSID I
is executed while a physical
nIRQ
signal from the VIC is still asserted?
Any architectural insights into how the Cortex-R5 VIC interface tracks de-assertion cycles under a masked CPSR state would be highly appreciated!
Thanks in advance,
Aswin
0
Aswin Sankar
1 month ago
Hi experts,
Could you please help me with your opinion?
Cancel
Vote up
0
Vote down
Accept answer
Cancel
