Unable to write to memory region marked as both writable and executable on cortex-R82
I am running on Cortex-R82 FVP.
EL2: MPU disabled with background region also disabled.
EL1: MPU enabled with multiple non-overlapping regions, background region disabled.
SCTLR_EL[2|1].WXN is set to 0.
Behavior: In EL1, when I write to a normal memory MPU region that has write and execute permissions enabled (around memory location 0x86400, if it matters), the write operation causes a fault. The issue disappears when the region is marked non-executable (prbar.XN bit is set).
My question is, if this is expected behavior or if it is an FVP parameter/bug? If it is expected, would be grateful if I could be pointed to the documentation that explains it further.
  • What syndrome is reported in the fault case? (I'm guessing permission fault, but thought it worth sanity checking)
    What are two different values you're writing into PRBAR?
  • Thanks for your reply, Martin! We ran the tests, and the issue is slightly different from what I explained above. Apart from "behavior" above, everything else holds true.
    Actual behavior: code does not execute from a memory region with write permissions, and results in an abort.
    Case: Execute from memory works
    prbar_el1: 0x56502c -> region marked as RO for EL1/EL0
    prlar_el1: 0x56811f
    Case: Execution from memory fails
    prbar_el1: 0x565024 -> region marked as RW for EL1/EL0
    prlar_el1: 0x56811f
    Execption Syndrom 0x8600000c Instruction Abort taken without a change in Exception level
    FAR 0x5662a0  (0xd2800007   MOV      x7,#0)
  • Thanks, that makes a bit more sense.
    I'm more familiar with the A-profile, which has a rule that a region which has write-permission at EL0 can _never_ be executable at EL1.
    From the A-profile spec (DDI0487, rev L.b), this is covered by R_VWLLR:
    For stage 1 translations that support two Exception levels, if UnprivWrite is present, then PrivExecute is removed.
  • Adding to my post:
    R-profile is a little different.  When the MPU is disabled there is a special case:
    “If the value of SCTLR_EL1.{M, BR} is {0, 1}, then for the Secure EL1&0 translation regime, any memory region that is writable at EL0 is also executable from EL1 if that address is marked as executable by the Background region.”
  • This is the issue, the Aarch64 memory model mentions: "A location with EL0 write permissions is never executable at EL1."
    Thanks for the hint!
