Does Cortex-A53 put stack in L1 data cache when the region is marked as uncacheable? ?
Hi everybody,
I am writing a program to put debug data in the 32KB L1 Data cache, then read back via method in A53 TRM section 6.7) direct access to internal memory.
I disable the data cache then put zero in DDR at address 0-32KB, then enable/invalidate data cache and do a sum of that 32KB. In theory A53 would move that 32K from DDR to L1D.
Then I read back the L1D, small portion of the data are non-zero, through the tag values I can trace the contamination to contents near the stack.
My program is stored in DDR region 16-24MB which I marked as NORM_NONCACHE. The program is approx. 20KB and works at EL3/baremetal with JTAG debugger attached.
What might have gone wrong with my method?
Thank you.
User_0182
  • Thank you Zhifei.
    My application particularly needs the L1 data cache to be not contaminated by unwanted data, that's why I mark many regions as uncache-able.
    How do I distinguish software breakpoint and hardware breakpoint?
    In my work I use Xilinx's Vitis, which is non-gdb. (I suppose gdb uses software breakpoint?)
  • Thank you Zhifei.
