Armv8-2 Error Injection Registers
Hi All,
With Armv8.2 RAS extension is available and in such context it is possible to inject some error for testing the software.
ARM provides for example those three system registers:
  • ERXPFGF_EL1
  • ERXPFGCTL_EL1
  • ERXPFGCDN_EL1
Looking at Arm Arm documentation those system registers are defined as S3_0_C5_C4_4/5/6 but if i have a look at Neoverse Trm i'm getting a different definition like
S3_0_C15_C2_0/1/2.
Does it mean that depending on the CPU those system registers change definition ? or is it an error ?
On Neoverse the definition based on C15 seems to be the right one while the C5 based one is not working.
Any feedback is welcomed.
Regards,
  • The ERXPFGF_EL1 of Neoverse N2 seems to be S3_0_C5_C4_4
    The ERXPFGF_EL1 of Neoverse N1 seems to be S3_0_C15_C2_0
    If you always use ERXPFGF_EL1 in your test code, it should be fine?
  • Can we have a single software binary image able to support both cou neoverse 1 and 2 at the same time ?
    compiler generated code should be different for two cores and so to me answer Is no. Which is annoying.
    Any reason for such difference ?
  • > Can we have a single software binary image able to support both cou neoverse 1 and 2 at the same time ?
    Yes. One workaround is that you read the CPUID register (MIDR_EL1), check the Neoverse N1/N2 type,  handle the ERXPFGF_EL1 for type result if you need.
    <quote>
    PartNum, [15:4]
    Indicates the primary part number. This value is:
    0xD0C Neoverse N1 core.
    </quote>
    I have no answers for that. But I am afraid that it is one kind of IMP-DEF while N1/N2 implements different RAS revisions.
