boot config Stm32g0
Hello
We bought a standard test board for stm32g0 micro , from China and we are testing it.
The vcc and vss are connected properly and .First boot0 pin is in program mode and then is run mode .
The reset button is on the same board and it connects the nrst pin to ground.
I created a simple "blinky" program by cube and downloaded the code by stink.
I set  boot0 to 1,the program runs correctly in debug mode But the program does not run ,outside the debug mode.
If you have any ideas in this regard, please guide me.
Thank You
