IRQ Execution in nRF51
Hello
I am using Seggar Embedded Studio for ARM V3.4 and nRF_SDK 12.3.0.
I am using nRF51 DK
I am trying to understand interrupts and interrupt handlers.
The interrupt request for Watchdog timer (i.e. void WDT_IRQHandler(void)) is not getting executed. The control is not going to WDT_IRQHandler.
I did the following attempts to verify if the control was going to WDT_IRQHandler()
1>I tried to switch on the LED
2>I tried to switch off the LED
3>Only a printf() statement inside WDT_IRQHandler() (in debug mode)
The above attempts did not work.
I have defined the following Preprocessor Definitions:-
NO_VTOR_CONFIG
BLE_STACK_SUPPORT_REQD
NRF51422
BOARD_PCA10028
SWI_DISABLE0
NRF51
I have attached main.c file and sdk_config.h files. Please let me know how can I achieve it.
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/* This example shows functionality of the Watchdog. The watchdog will reset the IC every 3 seconds if
 * it is not reloaded by pressing Button 1. LED 2 will blink during startup, which indicates that the
 * watchdog has restarted the IC.
#include <stdbool.h>
#include "nrf.h"
#include "nrf_drv_gpiote.h"
#include "app_error.h"
#include "boards.h"
#include "nrf_delay.h"
#define DELAY 100000
#define NR_OF_STARTUP_BLINKS 10
#define PIN_IN BSP_BUTTON_0
#define PIN_OUT BSP_LED_0
#define PIN_WDT BSP_LED_1
#define PIN_WDT_IRQ_HANDLER BSP_LED_2
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_drv_gpiote_out_toggle(PIN_OUT);
		NRF_WDT->RR[0] = WDT_RR_RR_Reload;  //Reload watchdog register 0
	nrf_drv_gpiote_out_toggle(PIN_WDT_IRQ_HANDLER);     //The WDT interrupt handler will have around 2 32kHz clock cycles to execute before reset, so you can not actully see this LED blink with your eye.
        printf("I M in IRQ\n");
 * @brief Function for configuring: PIN_IN pin for input, PIN_OUT and PIN_WDT pin for output,
 * and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
    ret_code_t err_code;
    err_code = nrf_drv_gpiote_init();
    APP_ERROR_CHECK(err_code);
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
	  err_code = nrf_drv_gpiote_out_init(PIN_WDT, &out_config);
		err_code = nrf_drv_gpiote_out_init(PIN_WDT_IRQ_HANDLER, &out_config);
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_IN, true);
void wdt_init(void)
	NRF_WDT->CONFIG = (WDT_CONFIG_HALT_Pause << WDT_CONFIG_HALT_Pos) | ( WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);   //Configure Watchdog. a) Pause watchdog while the CPU is halted by the debugger.  b) Keep the watchdog running while the CPU is sleeping.
	NRF_WDT->CRV = 3*32768;             //ca 3 sek. timout
	NRF_WDT->RREN |= WDT_RREN_RR0_Msk;  //Enable reload register 0
	// Enable WDT interrupt:
  NVIC_EnableIRQ(WDT_IRQn);
  NRF_WDT->INTENSET = WDT_INTENSET_TIMEOUT_Msk;
	NRF_WDT->TASKS_START = 1;           //Start the Watchdog timer
 * @brief Function for application main entry.
int main(void)
	gpio_init();
	//BLINK LED 2 during startup
	for(int i=0;i<NR_OF_STARTUP_BLINKS;i++)
		nrf_drv_gpiote_out_toggle(PIN_WDT);
		nrf_delay_us(DELAY);
	wdt_init();     //Initialize watchdog
    while (true)
			__WFE();
			__SEV();
			__WFE();
#ifndef SDK_CONFIG_H
#define SDK_CONFIG_H
// <<< Use Configuration Wizard in Context Menu >>>\n
#ifdef USE_APP_CONFIG
#include "app_config.h"
#endif
// <h> nRF_Drivers
// <e> CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver
#ifndef CLOCK_ENABLED
#define CLOCK_ENABLED 1
#endif
#if  CLOCK_ENABLED
// <o> CLOCK_CONFIG_XTAL_FREQ  - HF XTAL Frequency
// <0=> Default (64 MHz)
// <255=> Default (16 MHz)
// <0=> 32 MHz
#ifndef CLOCK_CONFIG_XTAL_FREQ
#define CLOCK_CONFIG_XTAL_FREQ 255
#endif
// <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
// <0=> RC
// <1=> XTAL
// <2=> Synth
#ifndef CLOCK_CONFIG_LF_SRC
#define CLOCK_CONFIG_LF_SRC 1
#endif
// <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
#ifndef CLOCK_CONFIG_IRQ_PRIORITY
#define CLOCK_CONFIG_IRQ_PRIORITY 3
#endif
// <e> CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef CLOCK_CONFIG_LOG_ENABLED
#define CLOCK_CONFIG_LOG_ENABLED 0
#endif
#if  CLOCK_CONFIG_LOG_ENABLED
// <o> CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef CLOCK_CONFIG_LOG_LEVEL
#define CLOCK_CONFIG_LOG_LEVEL 3
#endif
// <o> CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef CLOCK_CONFIG_INFO_COLOR
#define CLOCK_CONFIG_INFO_COLOR 0
#endif
// <o> CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef CLOCK_CONFIG_DEBUG_COLOR
#define CLOCK_CONFIG_DEBUG_COLOR 0
#endif
#endif //CLOCK_CONFIG_LOG_ENABLED
// </e>
#endif //CLOCK_ENABLED
// </e>
// <e> WDT_ENABLED - nrf_drv_wdt - WDT peripheral driver
#ifndef WDT_ENABLED
#define WDT_ENABLED 1
#endif
#if  WDT_ENABLED
// <o> WDT_CONFIG_BEHAVIOUR  - WDT behavior in CPU SLEEP or HALT mode
// <1=> Run in SLEEP, Pause in HALT
// <8=> Pause in SLEEP, Run in HALT
// <9=> Run in SLEEP and HALT
// <0=> Pause in SLEEP and HALT
#ifndef WDT_CONFIG_BEHAVIOUR
#define WDT_CONFIG_BEHAVIOUR 1
#endif
// <o> WDT_CONFIG_RELOAD_VALUE - Reload value  <15-4294967295>
#ifndef WDT_CONFIG_RELOAD_VALUE
#define WDT_CONFIG_RELOAD_VALUE 2000
#endif
// <o> WDT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
#ifndef WDT_CONFIG_IRQ_PRIORITY
#define WDT_CONFIG_IRQ_PRIORITY 3
#endif
// <e> WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef WDT_CONFIG_LOG_ENABLED
#define WDT_CONFIG_LOG_ENABLED 0
#endif
#if  WDT_CONFIG_LOG_ENABLED
// <o> WDT_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef WDT_CONFIG_LOG_LEVEL
#define WDT_CONFIG_LOG_LEVEL 3
#endif
// <o> WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef WDT_CONFIG_INFO_COLOR
#define WDT_CONFIG_INFO_COLOR 0
#endif
// <o> WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef WDT_CONFIG_DEBUG_COLOR
#define WDT_CONFIG_DEBUG_COLOR 0
#endif
#endif //WDT_CONFIG_LOG_ENABLED
// </e>
#endif //WDT_ENABLED
// </e>
// <e> APP_TIMER_ENABLED - app_timer - Application timer functionality
#ifndef APP_TIMER_ENABLED
#define APP_TIMER_ENABLED 1
#endif
#if  APP_TIMER_ENABLED
// <q> APP_TIMER_WITH_PROFILER  - Enable app_timer profiling
#ifndef APP_TIMER_WITH_PROFILER
#define APP_TIMER_WITH_PROFILER 0
#endif
// <q> APP_TIMER_KEEPS_RTC_ACTIVE  - Enable RTC always on
// <i> If option is enabled RTC is kept running even if there is no active timers.
// <i> This option can be used when app_timer is used for timestamping.
#ifndef APP_TIMER_KEEPS_RTC_ACTIVE
#define APP_TIMER_KEEPS_RTC_ACTIVE 0
#endif
#endif //APP_TIMER_ENABLED
// </e>
// <e> GPIOTE_ENABLED - nrf_drv_gpiote - GPIOTE peripheral driver
#ifndef GPIOTE_ENABLED
#define GPIOTE_ENABLED 1
#endif
#if  GPIOTE_ENABLED
// <o> GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins
#ifndef GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
#define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 1
#endif
// <o> GPIOTE_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
#ifndef GPIOTE_CONFIG_IRQ_PRIORITY
#define GPIOTE_CONFIG_IRQ_PRIORITY 3
#endif
// <e> GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef GPIOTE_CONFIG_LOG_ENABLED
#define GPIOTE_CONFIG_LOG_ENABLED 0
#endif
#if  GPIOTE_CONFIG_LOG_ENABLED
// <o> GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef GPIOTE_CONFIG_LOG_LEVEL
#define GPIOTE_CONFIG_LOG_LEVEL 3
#endif
// <o> GPIOTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef GPIOTE_CONFIG_INFO_COLOR
#define GPIOTE_CONFIG_INFO_COLOR 0
#endif
// <o> GPIOTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef GPIOTE_CONFIG_DEBUG_COLOR
#define GPIOTE_CONFIG_DEBUG_COLOR 0
#endif
#endif //GPIOTE_CONFIG_LOG_ENABLED
// </e>
#endif //GPIOTE_ENABLED
// </e>
// <e> PERIPHERAL_RESOURCE_SHARING_ENABLED - nrf_drv_common - Peripheral drivers common module
#ifndef PERIPHERAL_RESOURCE_SHARING_ENABLED
#define PERIPHERAL_RESOURCE_SHARING_ENABLED 0
#endif
#if  PERIPHERAL_RESOURCE_SHARING_ENABLED
// <e> COMMON_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef COMMON_CONFIG_LOG_ENABLED
#define COMMON_CONFIG_LOG_ENABLED 0
#endif
#if  COMMON_CONFIG_LOG_ENABLED
// <o> COMMON_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef COMMON_CONFIG_LOG_LEVEL
#define COMMON_CONFIG_LOG_LEVEL 3
#endif
// <o> COMMON_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef COMMON_CONFIG_INFO_COLOR
#define COMMON_CONFIG_INFO_COLOR 0
#endif
// <o> COMMON_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef COMMON_CONFIG_DEBUG_COLOR
#define COMMON_CONFIG_DEBUG_COLOR 0
#endif
#endif //COMMON_CONFIG_LOG_ENABLED
// </e>
#endif //PERIPHERAL_RESOURCE_SHARING_ENABLED
// </e>
// <e> UART_ENABLED - nrf_drv_uart - UART/UARTE peripheral driver
#ifndef UART_ENABLED
#define UART_ENABLED 1
#endif
#if  UART_ENABLED
// <o> UART_DEFAULT_CONFIG_HWFC  - Hardware Flow Control
// <0=> Disabled
// <1=> Enabled
#ifndef UART_DEFAULT_CONFIG_HWFC
#define UART_DEFAULT_CONFIG_HWFC 0
#endif
// <o> UART_DEFAULT_CONFIG_PARITY  - Parity
// <0=> Excluded
// <14=> Included
#ifndef UART_DEFAULT_CONFIG_PARITY
#define UART_DEFAULT_CONFIG_PARITY 0
#endif
// <o> UART_DEFAULT_CONFIG_BAUDRATE  - Default Baudrate
// <323584=> 1200 baud
// <643072=> 2400 baud
// <1290240=> 4800 baud
// <2576384=> 9600 baud
// <3862528=> 14400 baud
// <5152768=> 19200 baud
// <7716864=> 28800 baud
// <10289152=> 38400 baud
// <15400960=> 57600 baud
// <20615168=> 76800 baud
// <30924800=> 115200 baud
// <61865984=> 230400 baud
// <67108864=> 250000 baud
// <121634816=> 460800 baud
// <251658240=> 921600 baud
// <268435456=> 57600 baud
#ifndef UART_DEFAULT_CONFIG_BAUDRATE
#define UART_DEFAULT_CONFIG_BAUDRATE 30924800
#endif
// <o> UART_DEFAULT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
#ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY
#define UART_DEFAULT_CONFIG_IRQ_PRIORITY 3
#endif
// <q> UART_EASY_DMA_SUPPORT  - Driver supporting EasyDMA
#ifndef UART_EASY_DMA_SUPPORT
#define UART_EASY_DMA_SUPPORT 1
#endif
// <q> UART_LEGACY_SUPPORT  - Driver supporting Legacy mode
#ifndef UART_LEGACY_SUPPORT
#define UART_LEGACY_SUPPORT 1
#endif
// <e> UART0_ENABLED - Enable UART0 instance
#ifndef UART0_ENABLED
#define UART0_ENABLED 1
#endif
#if  UART0_ENABLED
// <q> UART0_CONFIG_USE_EASY_DMA  - Default setting for using EasyDMA
#ifndef UART0_CONFIG_USE_EASY_DMA
#define UART0_CONFIG_USE_EASY_DMA 1
#endif
#endif //UART0_ENABLED
// </e>
// <e> UART_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef UART_CONFIG_LOG_ENABLED
#define UART_CONFIG_LOG_ENABLED 0
#endif
#if  UART_CONFIG_LOG_ENABLED
// <o> UART_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef UART_CONFIG_LOG_LEVEL
#define UART_CONFIG_LOG_LEVEL 3
#endif
// <o> UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef UART_CONFIG_INFO_COLOR
#define UART_CONFIG_INFO_COLOR 0
#endif
// <o> UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef UART_CONFIG_DEBUG_COLOR
#define UART_CONFIG_DEBUG_COLOR 0
#endif
#endif //UART_CONFIG_LOG_ENABLED
// </e>
#endif //UART_ENABLED
// </e>
// </h>
// <h> nRF_Log
// <e> NRF_LOG_ENABLED - nrf_log - Logging
#ifndef NRF_LOG_ENABLED
#define NRF_LOG_ENABLED 0
#endif
#if  NRF_LOG_ENABLED
// <e> NRF_LOG_USES_COLORS - If enabled then ANSI escape code for colors is prefixed to every string
#ifndef NRF_LOG_USES_COLORS
#define NRF_LOG_USES_COLORS 0
#endif
#if  NRF_LOG_USES_COLORS
// <o> NRF_LOG_COLOR_DEFAULT  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRF_LOG_COLOR_DEFAULT
#define NRF_LOG_COLOR_DEFAULT 0
#endif
// <o> NRF_LOG_ERROR_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRF_LOG_ERROR_COLOR
#define NRF_LOG_ERROR_COLOR 0
#endif
// <o> NRF_LOG_WARNING_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRF_LOG_WARNING_COLOR
#define NRF_LOG_WARNING_COLOR 0
#endif
#endif //NRF_LOG_USES_COLORS
// </e>
// <o> NRF_LOG_DEFAULT_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef NRF_LOG_DEFAULT_LEVEL
#define NRF_LOG_DEFAULT_LEVEL 3
#endif
// <e> NRF_LOG_DEFERRED - Enable deffered logger.
// <i> Log data is buffered and can be processed in idle.
#ifndef NRF_LOG_DEFERRED
#define NRF_LOG_DEFERRED 1
#endif
#if  NRF_LOG_DEFERRED
// <o> NRF_LOG_DEFERRED_BUFSIZE - Size of the buffer for logs in words.
// <i> Must be power of 2
#ifndef NRF_LOG_DEFERRED_BUFSIZE
#define NRF_LOG_DEFERRED_BUFSIZE 256
#endif
#endif //NRF_LOG_DEFERRED
// </e>
// <q> NRF_LOG_USES_TIMESTAMP  - Enable timestamping
// <i> Function for getting the timestamp is provided by the user
#ifndef NRF_LOG_USES_TIMESTAMP
#define NRF_LOG_USES_TIMESTAMP 0
#endif
#endif //NRF_LOG_ENABLED
// </e>
// <h> nrf_log_backend - Logging sink
// <o> NRF_LOG_BACKEND_MAX_STRING_LENGTH - Buffer for storing single output string
// <i> Logger backend RAM usage is determined by this value.
#ifndef NRF_LOG_BACKEND_MAX_STRING_LENGTH
#define NRF_LOG_BACKEND_MAX_STRING_LENGTH 256
#endif
// <o> NRF_LOG_TIMESTAMP_DIGITS - Number of digits for timestamp
// <i> If higher resolution timestamp source is used it might be needed to increase that
#ifndef NRF_LOG_TIMESTAMP_DIGITS
#define NRF_LOG_TIMESTAMP_DIGITS 8
#endif
// <e> NRF_LOG_BACKEND_SERIAL_USES_UART - If enabled data is printed over UART
#ifndef NRF_LOG_BACKEND_SERIAL_USES_UART
#define NRF_LOG_BACKEND_SERIAL_USES_UART 1
#endif
#if  NRF_LOG_BACKEND_SERIAL_USES_UART
// <o> NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE  - Default Baudrate
#ifndef NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE
#define NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE 30924800
#endif
// <o> NRF_LOG_BACKEND_SERIAL_UART_TX_PIN - UART TX pin
#ifndef NRF_LOG_BACKEND_SERIAL_UART_TX_PIN
#define NRF_LOG_BACKEND_SERIAL_UART_TX_PIN 9
#endif
// <o> NRF_LOG_BACKEND_SERIAL_UART_RX_PIN - UART RX pin
#ifndef NRF_LOG_BACKEND_SERIAL_UART_RX_PIN
#define NRF_LOG_BACKEND_SERIAL_UART_RX_PIN 11
#endif
// <o> NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN - UART RTS pin
#ifndef NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN
#define NRF_LOG_BACKEND_SERIAL_UART_RTS_PIN 8
#endif
// <o> NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN - UART CTS pin
#ifndef NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN
#define NRF_LOG_BACKEND_SERIAL_UART_CTS_PIN 10
#endif
// <o> NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL  - Hardware Flow Control
// <0=> Disabled
// <1=> Enabled
#ifndef NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL
#define NRF_LOG_BACKEND_SERIAL_UART_FLOW_CONTROL 0
#endif
// <o> NRF_LOG_BACKEND_UART_INSTANCE  - UART instance used
// <0=> 0
#ifndef NRF_LOG_BACKEND_UART_INSTANCE
#define NRF_LOG_BACKEND_UART_INSTANCE 0
#endif
#endif //NRF_LOG_BACKEND_SERIAL_USES_UART
// </e>
// <e> NRF_LOG_BACKEND_SERIAL_USES_RTT - If enabled data is printed using RTT
#ifndef NRF_LOG_BACKEND_SERIAL_USES_RTT
#define NRF_LOG_BACKEND_SERIAL_USES_RTT 0
#endif
#if  NRF_LOG_BACKEND_SERIAL_USES_RTT
// <o> NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE - RTT output buffer size.
// <i> Should be equal or bigger than \ref NRF_LOG_BACKEND_MAX_STRING_LENGTH.
// <i> This value is used in Segger RTT configuration to set the buffer size
// <i> if it is bigger than default RTT buffer size.
#ifndef NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE
#define NRF_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE 512
#endif
#endif //NRF_LOG_BACKEND_SERIAL_USES_RTT
// </e>
// </h>
// </h>
// <h> nRF_Segger_RTT
// <h> segger_rtt - SEGGER RTT
// <o> SEGGER_RTT_CONFIG_BUFFER_SIZE_UP - Size of upstream buffer.
#ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_UP
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 64
#endif
// <o> SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS - Size of upstream buffer.
#ifndef SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS
#define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
#endif
// <o> SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN - Size of upstream buffer.
#ifndef SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
#endif
// <o> SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS - Size of upstream buffer.
#ifndef SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS
#define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
#endif
// </h>
// </h>
// <<< end of configuration section >>>
#endif //SDK_CONFIG_H
