Site
Search
User
Site
Search
User
Forums
compile time constant expressions
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
compiler
optimization
Arm9
arm926ej-s
MPI
Options
More actions
Cancel
Related
Mike Rieker
over 13 years ago
Note: This was originally posted on 12th March 2009 at
http://forums.arm.com
I am seeing code like this generated from the armcc v4.0 compiler (just downloaded it a couple hours ago):
MOV r0,#5
CLZ r0,r0
RSB r7,r0,#0x3f
So I would think the compiler would know that R7 has 34 in it or whatever. It isn't so bad these three instructions, it's just that in this case the code goes on to divide by the r7 value and so generates a call to __aeabi_uldivmod whereas I was expecting the compiler to generate a UMULL or something like that.
Is there some command-line optimization option I can use to fix this? I am using this command line:
armcc --cpu=ARM926EJ-S --inline -Otime -O3 -S -o test.s test.c
Thanks!
Mike
Top replies
Simon Craske
over 13 years ago
+1
verified
Note: This was originally posted on 13th March 2009 at http://forums.arm.com There isn't a count leading zero construct in the C language, so presumably it's something like: [font="Courier New"]int func...
+1
Simon Craske
over 13 years ago
[font="Courier New"]int func(void)
return 63 - __clz(5);
}[/font]
Using RVCTs __clz() instrinsic.
hth
s.
Cancel
Vote up
+1
Vote down
Cancel
+1
Simon Craske
over 13 years ago
}[/font]
hth
s.
Cancel
Vote up
+1
Vote down
Cancel
