Site
Search
User
Site
Search
User
Forums
ARM1176JZ-S, cache confg: effective cache size calculation
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
ARM1176JZ-S
Arm11
Options
More actions
Cancel
Related
deven deven
over 13 years ago
Note: This was originally posted on 22nd February 2009 at
http://forums.arm.com
1) I am using ARM1176JZ-S core with WinCE Platform. The cache memory is configured as follows
DCache: 128 sets, 4 ways, 32 line size, 16384 size
ICache: 128 sets, 4 ways, 32 line size, 16384 size
Now I want to know the effective data cache size, I mean the total data from the main memory
could be cached and accessed without cache trashing within a function.
2) Is the cache set size(128 sets) and cache block/segment(of other processors) size are same?
Kindly reply this mail, thanks in advance
Regards,
Deven
Top replies
Peter Harris
over 13 years ago
+1
verified
Note: This was originally posted on 9th March 2009 at http://forums.arm.com Assuming that your QUERY_START and QUERY_END macros are calling a system function to get the time stamp, I would think that you...
+1
Peter Harris
over 13 years ago
Assuming that your QUERY_START and QUERY_END macros are calling a system function to get the time stamp, I would think that you are spending a significant time in the kernel to actually process the time request.
Your test loop is quite short (64K ops, from cache, may only be 100K-200K cycles). There is an off chance that the system call is much slower than this (in most OSes the system calls are expensive) and because your loop has just saturated the D cache it will run even slower than it would normally.
Functions like printf are also quite data heavy, so you may find you are corrupting a significant chunk of the cache that you think you have preloaded, but in fact evicting it by printf'ing before calling the test loop.
(If you are using the CP15 performance counters, you are in with half a chance. You can also measure the cache misses for both I and D to sanity check your results).
Constructing benchmarks to measure cache effects can be quite difficult, especially on top of an operating system...
Cancel
Vote up
+1
Vote down
Cancel
+1
Peter Harris
over 13 years ago
Cancel
Vote up
+1
Vote down
Cancel
