Site
Search
User
Site
Search
User
Forums
How to get Call Stack from stack data.
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
347 subscribers
Views
Users
0 members are here
register
Cortex-M
Debugger
Options
More actions
Cancel
Related
Mountain Mountain
over 13 years ago
Note: This was originally posted on 23rd January 2009 at
http://forums.arm.com
Hi everyone.
Here is a question that puzzled me a long time. if I get stack data(HEX data), anyone konw that how to get call stack from it.
How to know that which is R14.
0
Mountain Mountain
over 13 years ago
Note: This was originally posted on 25th March 2009 at
Thank you for all your reply.
Recently, I am studying a new platform, when system crash, it can output all task stack data and also identify which is R14 in the stack data as the following:
[color="#FF0000"] [0a0243fc/821933fc]=00003320 TCC_Task_Shell() [/color]
[0a0243f8/821933f8]=00000000
[0a0243f4/821933f4]=00000000
[0a0243f0/821933f0]=00000000
[0a0243ec/821933ec]=00000000
[color="#FF0000"] [0a0243e8/821933e8]=0000332f TCC_Task_Shell() call FuncPtr (Thumb BLX R0)[/color] [0a0243e4/821933e4]=00000000
[0a0243e0/821933e0]=00000000
[0a0243dc/821933dc]=00000000
[0a0243d8/821933d8]=813085ec
[0a0243d4/821933d4]=000b4ba8
[0a0243d0/821933d0]=80eb4bd4
[0a0243cc/821933cc]=000b4ba8
[0a0243c8/821933c8]=00000001
[0a0243c4/821933c4]=00000000
[0a0243c0/821933c0]=00000000
[color="#FF0000"][0a0243bc/821933bc]=000000c0 TCT_Control_Interrupts()
[0a0243b8/821933b8]=8110bec7 capi2driverTask_Entry() call(Thumb BL) CAPI2_HandleEvent() [/color] [0a0243b4/821933b4]=81372868
[0a0243b0/821933b0]=00000011
[0a0243ac/821933ac]=00000000
[0a0243a8/821933a8]=81905240
[0a0243a4/821933a4]=81905220
[color="#FF0000"] [0a0243a0/821933a0]=80f7849f CAPI2_HandleEvent() call(Thumb BL) CAPI2_DispatchMsg() [/color] [0a02439c/8219339c]=81372868
and the wonderful comments in the specification:
[color="#FF0000"] Red colored lines are the actual function call traces[/color] The others can be ignored (they are registers/parameters/
local variables pushed into the stack when a function is called)
How to implement it.
Thank you very mcuh
Cancel
Vote up
0
Vote down
Cancel
0
unclep unclep
over 13 years ago
Note: This was originally posted on 28th January 2009 at
Debuggers can do this for you from the code image (such as an .axf file if using RVCT). The image file contains debug information about what each function saves on the stack.
For example, follow the link to the ARM Support Knowledgebase on these forum pages, and search for "call stack" to see RVD features for this.
Cancel
Vote up
0
Vote down
Cancel
0
vicerobinson vicerobinson
over 13 years ago
Note: This was originally posted on 7th December 2009 at
Of course, this only works because C functions will be ABI compliant and thus don't mess up the stack pointer. If you write a function in assembly which doesn't correctly handle the stack pointer, everything will fall apart because what should be stored in r14 will end up somewhere else.
Cancel
Vote up
0
Vote down
Cancel
0
Jacob Bramley
over 13 years ago
Interesting question.
Basically, the stack works because you read values off it in the opposite order to that which they were stored. r14's entry in the stack will not be obviously labelled as such, for example.
Also, note that there may be many copies of r14 in the stack as it will be pushed every time a function needs to modify it. As r14 is the link register, that will occur for pretty much every function call.
The only way to determine where r14 is located in the stack is to study your code and work out the address at which it will eventually be stored. Of course, you can use a debugger to do that for you by setting breakpoints and that kind of thing.
Does that answer your question?
Cancel
Vote up
0
Vote down
Cancel
