Site
Search
User
Site
Search
User
Forums
help needed on Timers in ARM9
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Arm9
Interrupt
Options
More actions
Cancel
Related
sgupta sgupta
over 13 years ago
Note: This was originally posted on 5th January 2009 at
http://forums.arm.com
hi....i just want to know........
hw we can program the timers to generate interupt after a specified period of time..
which mode should we use, and hw to calculate timer register values if they need to be specified..
plz help..
Top replies
Jack12345 Jack12345
over 13 years ago
+1
verified
Note: This was originally posted on 13th January 2009 at http://forums.arm.com Hi, Arm Architecture Does not support Timers. Timers is just another Peripheral in the SOC. U need to get the data sheet of...
+1
Jack12345 Jack12345
over 13 years ago
Arm Architecture Does not support Timers. Timers is just another Peripheral in the SOC. U need to get the data sheet of the Timer which is the part of your SOC and then program accordingly.
i have worked on DM320 SOC with Arm926ejs on it.
Each of the general-purpose timers can run in one of two modes: one-shot
mode or free-run mode.
Once the prescale and divider values of the timer are set and the timer is
started, the prescale is decremented by one for every input clock cycle. Each
time the prescale value reaches ‘0’, the divider register is decremented by one
and counter register incremented by one. Also the prescale register is reloaded
with the programmed value. When the divider reaches zero, the timer generates
an interrupt.
In one-shot mode, an interrupt occurs only once, when the timer divider reaches
zero and then the timer must be explicitly re-triggered to begin the operation
again
In free-run mode, when the timer generates an interrupt, the divider value is
automatically reloaded with the programmed value to start the count operation
again.
Timer Interrupt frequency = clock frequency /(prescale+1)(Divider+1)
Hence u write those registers (Prescale and divider) accordingly.
Hope this helps.
Cancel
Vote up
+1
Vote down
Cancel
0
Jacob Bramley
over 13 years ago
Note: This was originally posted on 7th January 2009 at
The timers will be third-party peripherals and not part of the ARM architecture itself. The consequence of this is that the chip vendors will often use their own peripheral implementations, and these often differ. Therefore, you will need to consult the documentation for the specific chip you have in order to use the timer peripheral. This information is readily available from most manufacturers' websites.
I am pretty certain that your timer will be able to implement the behaviour you require as it is a fairly common function.
Cancel
Vote up
0
Vote down
Cancel
