Site
Search
User
Site
Search
User
Forums
hard fault with Cortex M1
Jump...
Cancel
State
Not Answered
Locked
Locked
Replies
Subscribers
347 subscribers
Views
Users
0 members are here
Cortex-M1
Cortex-M
firmware
Options
More actions
Cancel
Related
sumit sumit
over 13 years ago
Note: This was originally posted on 24th December 2008 at
http://forums.arm.com
Hi all,
I am developing firmware on Cortex M1 on Actel fusion FPGA.I have built the design that has sram at 0x0 location ,size is 1mb and I use it as my program memory.I have Ethernet interface and I want to debug the driver for the ipcore.
I am facing the problem due to hard fault.When I start the transmission on the Ethernet,after transmission first frame the cortex goes to hard fault.
Would anyone tell me what may be the reason for hard fault? How to overcome?
I am completely new to arm environment.
regards,
Sumit
0
Tobias Hondorf
over 13 years ago
Note: This was originally posted on 8th December 2009 at
I get a hardfault expection aswell. I checked my pointers, everything seems to be OK. I'm currently porting an microKernel to the M1, so i adjust StackPointer to different Stacks in Memory (Task Control Blocks) i checked my code, i don't think i make a misstake there. But it seems the the crash occures after the ContextSwitch. And it only occures in running mode, when i step i never leave the IRQ handler, but this might be because interrupts coming fast enough to inflict a new IRQ before i stepped through one.
Well i sticked a breakpoint to the begin of the HardFault handler, and checked the memory adress of the StackPointer+24. This should be the ReturnAddress that has been saved automaticly on the stack while entering the (fault) exception. But for some reason i got only the initial value (a5a5a5a5) of this memory section at the address. There seems to be nothing written. I got a value in the saved LR (SP+20) and a value in the saved xPSX (SP+28) memory, which seems to be both correct.
How can this happen? Since the procedure which pushes the 8 registers on entry of exception on the stack is pushing xPSR than returnAdress and than LR. So i't cant be an issue with abort of this push function - if there were the LR have to be empty aswell.
I just wonder how to track this error. I have no idea how to debug this.
I afforded 2 days in verifying my code with teammates, cant find an error there. Neither in the C Source nor in the Assembly which contains the context switch.
I already wrote a port for another kernel, worked and was easy going.
From all what i can find in the Reference Manuals, the Internet and this Forum it seems to be an issue with the Stackpointer, but in stepping mode its working as expected. And i reviewed my program architecture - dont think the error is coming from there.
What ever, I'd really appreciate it if someone got an idea how to backtrack this hardfault. Thanks in advance.
Cancel
Vote up
0
Vote down
Cancel
0
Tobias Hondorf
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
