Site
Search
User
Site
Search
User
Forums
Testing for interrupt
Jump...
Cancel
State
Accepted Answer
+1
person also asked this
people also asked this
Locked
Locked
Replies
Subscribers
348 subscribers
Views
Users
0 members are here
Interrupts
Arm7tdmi
RM7
Options
More actions
Cancel
Related
Upp3r Upp3r
over 13 years ago
Note: This was originally posted on 19th November 2008 at
http://forums.arm.com
Im looking for a way to test if there is an interrupt currently processing on my ARM7. I can see that the interrupt disable bits are set to disable the FIQ and IRQ interrupts, but are they set when an interrupt is triggered? In my "TMS470R1x User's Guide" in the section on Exceptions, it gives a run down when an exception occurs and it says it "may also set interrupt disable flags" but nothing decisive.
My question is: Do the CPSR I and F bits signify there is an interrupt in progress, i.e, when an interrupt occurs, is the disable flag set? If not, how could I determine if there is an interrupt in progress?
Top replies
Jacob Bramley
over 13 years ago
+1
verified
Note: This was originally posted on 20th November 2008 at http://forums.arm.com The CPSR I and F bits do not indicate that an interrupt is in progress. They do nothing other than enable or disable interrupts...
0
Ojin Choi
over 13 years ago
When the interrupt occurs (nIRQ and nFIQ), the flags of the CPSR was set (disable).
So you don't worry about it.
Cancel
Vote up
0
Vote down
Cancel
+1
Jacob Bramley
over 13 years ago
The CPSR I and F bits do not indicate that an interrupt is in progress. They do nothing other than enable or disable interrupts. However, a side effect of an interrupt being triggered is that the respective CPSR bit will be set* in order to prevent the same interrupt to occur again. If this didn't happen, the LR could be corrupted before it can be stacked and it would be practically impossible to build a robust system. Nested interrupts are possible, but you need to fiddle about somewhat in order to make them work as expected.
* In addition, an FIQ will cause IRQs to be disabled as FIQs are intended to be high-priority fast interrupts for time-critical events.
Note, however, that each mode has its own SPSR, and it is usual to copy this SPSR to the CPSR before returning from the interrupt. Doing this will restore the I and F bits (along with the processor mode) to whatever they were before the interrupt was triggered.
Also, check that you know what you mean when you say "an interrupt currently processing". It is rare that the code itself needs to check if it's running in interrupt context as the program flow automatically branches to the exception handler. It's more likely that you'd need to check this from a debugger, but even then the interrupt code is almost always different from the main program code. Why do you need to determine if there is an interrupt in progress, and from what context do you need to perform this check?
Cancel
Vote up
+1
Vote down
Cancel
0
Jacob Bramley
over 13 years ago
In addition, you may find this page useful: [url="
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0210c/CIHEHHJJ.html
http://infocenter.arm.com/help/index.jsp?t...c/CIHEHHJJ.html[/url]
Cancel
Vote up
0
Vote down
Cancel
